Author Topic: supercharging an 8v gti  (Read 18511 times)
Offline bored_Welsh_lad
Re: supercharging an 8v gti
« Reply #100 on: 16 January 2010, 14:01 »
don't spend money on headwork,   not worth it with boost  you'll just notice your boost pressure drop a bit  it's cheeper just to make the charger blow harder
Danny, i thought you were running a valver.. I was talking to nando about the 8v and he said the power that was quoted by alldubs 8v was not at 10psi on the standard pulley but 5psi with the head choking up at 5k and backfilling to 10psi.. Nando said the major limiting factors on the 8v is the flowrate of the exhaust manifold and head.. He said to flow decent boost it needs a decent head, making the charger flow more will only induce more heat surely?
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline Khare
  • The bear that khares
« Reply #101 on: 16 January 2010, 16:40 »
DH said I can get a ported and polished head from a tuning company, forgot the name now, for £250..I might invest into it.
Offline axewielder
  • 95 dragon 8v
« Reply #102 on: 16 January 2010, 18:17 »
the ABA had lower compression in standard form as most engines for usa market do.
std ABA compression ratio 9:1 iirc ,  you get the cr as useing 2 headgaskets on a european engine but keep the quish zone roun the edge of the cylinder whitch is a feature
so the extra volume was gained through the piston+ not the combustion chamber in the head being larger?
« Reply #103 on: 16 January 2010, 18:37 »
was that not the man in the shed on cgti?
Bumper Vents :D
Offline axewielder
  • 95 dragon 8v
« Reply #104 on: 16 January 2010, 18:40 »
the man in the shed's work look pretty good but do you know whether he uses any kind of flow bench to test his work or isit all by eye, if so in NA aplications it can do more bad than good, a charged engine should be fine though but would be better if all ports flowed equally or closa too for smoothness
Offline Khare
« Reply #105 on: 16 January 2010, 20:58 »
not it was a tuning company, JLE or something like that, can't remember.
Offline Larrychips
« Reply #106 on: 17 January 2010, 08:41 »
Quote
I was looking into supercharging my 8v GTi too...although, I have now decided to save the cash and buy a VR6.  You could spend upwards of £3000 on the 2.0 8v engine, and you'll still only end up with the same power as a bog standard VR6.  Anyway...while I was doing a little research, I found this http://www.cncheads.co.uk/vw_golf_8v_bv.html.  For £250 they take your head and machine it out to increase flow rates.  I was thinking about doing this...and upgrading the cam & injectors at the same time...   hope this helps...
1997 Black Mk3 Golf 2.0 8v GTi
Full exhaust system/remapped/Air-Filter...mmm...and thats it for now...  PS- Must change this picture! Its too big and due to a speed bump under my rear right wheel, the front right looks like its in the air  ><
VeeDubGTI16v
« Reply #107 on: 17 January 2010, 09:06 »
£250? you'll be lucky  :grin:
i know the 16v heads are £750 +vat
« Reply #108 on: 18 January 2010, 17:30 »
Talking of headwork.. if your serious about having work done it might be worthwhile having a read of this to see where the gains are to be had...
http://www.clubgti.com/forum/showthread.php?t=202798
Bumper Vents :D
