Author Topic: top mount fitment (mk3 golf)  (Read 9152 times)
Offline stainesy
Re: top mount fitment (mk3 golf)
« Reply #10 on: 14 January 2010, 21:26 »
i can borrow a tracking gauge from work but how do i check and adjust my camber?
Offline axewielder
  • 95 dragon 8v
« Reply #11 on: 15 January 2010, 10:03 »
loosen bolt 29 in the above diag + hold it in right position + then re tighten
« Reply #12 on: 15 January 2010, 10:16 »
You really need the proper kit to be honest.
Offline stainesy
« Reply #13 on: 15 January 2010, 11:46 »
cant i draw around the hub bolts on sespension leg wile on as it is then but it all back so bolts are in same place. also use a spirit levil on wheel edge when parked on flat service?
« Reply #14 on: 15 January 2010, 11:47 »
Maybe but it would still be best to get it checked.
Offline shepgti
« Reply #15 on: 15 January 2010, 15:17 »
they draw round the postion in the haynes manual so all good  :wink:
Offline axewielder
  • 95 dragon 8v
« Reply #16 on: 15 January 2010, 15:23 »
ive done that but getting it all right again is a pain especially when on your own, best is to get it all as close as poss+ then get it done on a pro one, the local high tech one is £40 i think, just make sure u do all sus parts at once otherwise ull have to do it all again.
You could measure it all ure self but itd be alot of measuring+ make sure everything is level+ straight+ would be best to get one of those digi inclinometers
Offline stainesy
« Reply #17 on: 15 January 2010, 16:24 »
ok right gona now do the work as close as posible then take it to get checked.
what will be a good cheap place to tyake it. i.e quick fit or something?
Christo77
« Reply #18 on: 15 January 2010, 16:26 »
I'd agree with that,
When i did my suspension i paid particular attention to getting the strut legs to hub back to the same position best i could using a spirit level and marking the positioning before removal...still, i was left with my steering wheel slightly off centre! so something wasn't quite right.. Very hard to get it spot on,  Only a proper tracking/camber alignment job at a specialist will do that.
Christo
Offline stainesy
« Reply #19 on: 15 January 2010, 17:00 »
just phoned a place in luton near me called tyre city and they said it is about £28 per adjustment so could go up to like £80
