Author Topic: URGENT HELP NEEDED...VR6 ENGINE...:(  (Read 2350 times)
Offline alirkhan
Re: URGENT HELP NEEDED...VR6 ENGINE...:(
« Reply #10 on: 13 January 2010, 10:12 »
ghetto style..!! how wud that be?!!..i need to drive the car and take it 40 kms away to the workshop..would wanna sav the cost of a tow truck  :grin:..but guyss..uve ben great!!..i hope it doesnt damage the engine?! :evil:
Offline Horney
« Reply #11 on: 13 January 2010, 10:18 »
No it'll be fine. What you want to do is connect the pipes up so they run the same way as if the box was still there but replace the box with some copper or plastic pipe. Does that make sense?
It won't do any damage as it's just to reduce noise and if you run a shrick inlet manifold you actually have to remove this damper from the system.
nick
Offline alirkhan
« Reply #12 on: 13 January 2010, 11:23 »
so u think a can of coke will do the trick! :wink:
Offline MK3TDi1996
« Reply #13 on: 13 January 2010, 14:30 »
no way man, use cream soda, much better build quality ;)
Offline popleyruss
« Reply #14 on: 14 January 2010, 13:21 »
think this could be the same problem on my vr aswell
Just plain dubbin
Offline alirkhan
« Reply #15 on: 16 January 2010, 14:48 »
THANKS GUYS!!...check out my ghetto sytle replacement idle engine valve damper till the new one rocks up frm germany!...iteams needed...one hose pipe, one two way pipe connecter..some leak sealent..and a lot of brains :p...cheers !
Offline MK3TDi1996
« Reply #16 on: 16 January 2010, 16:40 »
Lookin good man! - love the twin hose ;)
Offline b1gdub
  • MK4 1.8T AGU
« Reply #17 on: 16 January 2010, 23:27 »
Sorted.
