Author Topic: Blocking off a blown matrix..  (Read 2137 times)
Offline jamie_pyrite
Re: Blocking off a blown matrix..
« Reply #10 on: 14 January 2010, 01:41 »
Plan is to get up early and start stripping stuff off and get a couple of hairdryers on the carpets! Bypassing went well. I found the perfect piece of angled copper pipe in the garage.
« Reply #11 on: 14 January 2010, 08:47 »
I would try and get the carpet out, I would suspect the foam underneath will be soaked.
« Reply #12 on: 14 January 2010, 20:58 »
Indeed the underlay was completely soaked through!! What's the best thing to do about replacing it? I have a load of top quality house underlay I could use, or is that a bit too pikey?
So I got most of it off today, everything undone but ran out of time before pulling the matrix out. On the main section there's a really big flap, this was cable tied shut! Where it pivots, at the bottom looks broken. What's meant to be attached to there?
I'm guessing at some point, something has snapped off there and the owner has just decided to cabletie the air flap shut?!
Offline tony_ack
« Reply #13 on: 14 January 2010, 21:45 »
The underlay is for sound-proofing purposes, so it's really up to your judgement on what you want to replace it with. The only benefit that I can see that the original underlay has over some other generic stuff is that it has a spashproof top which will stop most of the water from general use (i.e. from your shoes) from soaking through the carpet and directly into the underlay. I guess it would be easy to create something similar.
I got mine from a MK3 and cut it to roughly the right size.
Check the floorpan for rust, treat any you can see, and make sure it is uber-dry before you start building it up again. I let mine dry over a couple of days, and sprayed some waxoyl in there for good measure to tease out the last of the moisture and matrix-proof the floorpan for the future  :smiley:
I'm guessing the really big flap you're referring to is the temperature mixer on the front of the heaterbox? The control levers are connected via cables to some gearing on the left hand side of the heaterbox, which controls the flap. If anything on there looks broken, I'd look at replacing the whole heaterbox. Anyone breaking a later Mk2 should be able to supply one for a reasonable price, though as you now probably realise, it's a bit of a ballache to get out. If you do replace it, make sure you replace the heaterbox and controls as one - once you disconnect the control cables, you're going to struggle to get them lined up properly again.
I really don't understand why a previous owner cable-tied it shut, unless it was flapping around. Even so, if you strip it down enough to get to the flap, then why not replace the thing?? What's the point in doing a half-arsed job, when only it only takes a little more effort to do it properly??
« Last Edit: 14 January 2010, 21:48 by tony_ack »
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
« Reply #14 on: 15 January 2010, 19:35 »
Thanks for the info! I'm going to leave the underlay out to dry for a few weeks and see if it smells or not! There is surface rust so I'll be treating that tomorrow. Just a sand back then some hammerite should do the trick!
I've no idea about the cable tie either. Such a strange bodge.. I'll get it all out tomorrow and work out what's what and if I can get away with not replacing the whole thing!
I've obviously knocked a wire or something because tonight the alarm started going off constantly and wouldn't turn off! Battery has been disconnected for now..
« Reply #15 on: 16 January 2010, 15:54 »
Well I've got it out! Bit of a pig of a job. Here's some pics to show the heater box. The first pic show the big flap that was cable tied closed:
and this shows where the cables mount onto the flap pivots:
Better see if anyone is breaking a mk2! Unless this is fixable? There are three cables that go from the controls to the box. Am I missing anything?
Thanks
Offline gavL
« Reply #16 on: 16 January 2010, 15:56 »
http://www.dubnortheast.co.uk/forum/index.php/topic,4435.0.html
| DubNorthEast |
