Author Topic: Any one that can help me with these fault codes????  (Read 1428 times)
Offline craigy
« on: 10 January 2010, 10:58 »
1 Fault Found:
00771 - Fuel Level Sensor (G)
            30-10 - Open or Short to Plus - Intermittent
16725 -  Camshaft Position Sensor (G40): Implausible Signal
            P0341 - 35-00 -  -
16804 -  Catalyst System; Bank 1: Efficiency Below Threshold
            P0420 - 35-00 -  -
16502 -  Engine Coolant Temp. Sensor (G62): Signal too High
            P0118 - 35-10 -  - - Intermittent
My car is an 2001 aum it doesnt start til a keep buzzing the fuel pump on and of about 3 times or more but i dnt no weather that would be dwn til fuel fault code or the camshaft fault code
Offline T_J_G
Re: Any one that can help me with these fault codes????
« Reply #1 on: 10 January 2010, 11:18 »
google Ross Tech Wiki and copy the codes into that
Offline craigy
« Reply #2 on: 10 January 2010, 11:32 »
ok thanks
Offline snap-on
« Reply #3 on: 10 January 2010, 21:28 »
reason it wont start straight away is prob to do with coolant temp sensor reading the wrong temp !
code p0118 change the coolant temp sensor , rubber o ring and clip (around £28 from dealer)
code p0420 is the cat converter , is it standard or decatted ? if standard you need a new cat
code p0341 has it had a cambelt change recent ?
i would start by changing the temp sensor first as this will make the car start and run correctly and then clear all codes as it could well be the cause of the p0420 cat code cos the fuelling is incorrect , and go from there
