I removed the ABS from my car, was a great big head ache and hard work...
but worth it, was happy with end result
![smiley :smiley:](https://www.golfgtiforum.co.uk/Smileys/modern/smiley.gif.pagespeed.ce.MHhbeXpJjm.gif)
You need to re-plumb all your brake pipes from the master cylinder to each wheel, i got all the pipes and fittings made up at local
car factors
also you need to fit a brake bias valve for the rear brakes some where because its normally controlled by the abs pump,
if you fit a manual adjusting valve, someone told me it cant be inside car within drivers reach for MOT (dont know if this is true)
so i fitted mine under bonnet where the ABS pump was before
