Author Topic: Heated Mirror Broken?  (Read 10819 times)
Offline NewbieGTi
Re: Heated Mirror Broken?
« Reply #10 on: 06 January 2010, 14:11 »
yes the element is on the back of the mirror glass and the connector wires attach to the back of the mirror.
Could it be a fuse by any chance? Is there a way of checking whether the wires that connect to the mirror are producing current using a multi-metre thing?
Good point I will double check, all the other electrics seem OK as far as I can tell.
MK5 (06) GTI; Previous: (57) Audi A3 2.0 TDI & (05) Seat Leon Cupra R 225 & (51) Seat Ibiza Cupra 1.8 20VT
Offline ub7rm
« Reply #11 on: 06 January 2010, 14:41 »
If one is working but the other isn't its almost certainly not the fuse.  Checking there is voltage coming into the glass is a good shout, if there is then its deff the heating element in the glass thats failed.
2020 BMW 128ti
2017 Golf GTD Estate
Offline bobotheclown
« Reply #12 on: 07 January 2010, 13:25 »
http://oemplus.com/diy/article_info.php?articles_id=15&osCsid=927e264a2df2b9749578e7134ca6ccad
guide to taking off the wing mirror cover, possibly. can't check the link at work
Offline NewbieGTi
« Reply #13 on: 07 January 2010, 14:08 »
Doh it says link not found  :sad:
« Reply #14 on: 07 January 2010, 14:53 »
oh bugger. It was in their DIY section. Must be down or deleted. Link Fail me thinks
Offline mortygt140
« Reply #15 on: 09 January 2010, 15:52 »
When I original bought my golf the passenger side glass wouldn't work,  looking on VCDS it brought up a fault about passenger heater element open or short to plus or something,  VW replaced the glass under warranty,  if it not in warranty then the glass is about £30 from VW
Darren
