Author Topic: Its That ABS thing again  (Read 1775 times)
Offline adyh
« on: 18 October 2004, 16:56 »
Right ,
basically the situation is this , a couple of months back the ABS warning ligh t would come on for a while every now and again , this has now become a permenant fixiture .
I read the fault code originally and it registered a sensor as intermittent and now as failed .
Think it was a loose wire if had the wheel off and can find nothing loose  .
Any idea how much its going to cost to get this sensor changed ?
And three weeks from MOT day as well
Offline Burnsy
Re: Its That ABS thing again
« Reply #1 on: 20 October 2004, 14:32 »
Im sure when i went in to inquire about a new front sensor they quoted me 40 odd quid and thats just the part.
If you need to get it through Mot and cant afford to replace it then just unplug it from behind the illuminated panel :D
Naughty i know but they wont detect it any other way
Offline adyh
« Reply #2 on: 20 October 2004, 15:18 »
I may unplug the bulb and get it fixed in the new year  .
Cheers for the info  .
Offline wombar
« Reply #3 on: 21 October 2004, 08:36 »
You can get a new part from GSF and fit it yourself for about ?45, if you've got somewhere you can jack it up and axle stand it.
Christ if I can do it anyone can. I just didn't fancy paying VW ?170 to do it. It'll take you an afternoon but thats gotta be worth the money you'll save. Give me a shout if you want some advice on how to do it.
Offline adyh
« Reply #4 on: 21 October 2004, 10:54 »
Cheers mate  . Ive had a look at ETKA and it looks fairly simple just held in with a bolt [ am i right ?] .
Offline actionslax
« Reply #5 on: 21 October 2004, 12:16 »
i've this problem too but the light has now gone off. a diagnostic test said the sensor was knackered nr side front.
can anyone point me in the direction of the instructions also, and a place to buy the sensor. if possible?
cheers in advance
currently rattling:
1. To make or emit a quick succession of short percussive sounds.
2. Not anymore - Now rumbling
