Author Topic: warning light  (Read 2192 times)
Offline FamilyDub
Re: warning light
« Reply #10 on: 04 January 2010, 15:21 »
took it to a vw specialist this morning for his software not to read my 54 plate. then took it to my normal garage and they took the car straight in the garage and hooked it up. problem with the ciol pack or something like that. covered on the warranty tho so its all good, getting it serviced too while its there
Ah, ok. Coil pack.
That's fairly common & not an expensive fix anyway. Think they're about £25 each (one per cylinder), so shouldn't be a long job :afro:
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
