Author Topic: half done suspension  (Read 1628 times)
Offline hyland770
  • Vw Golf 1.6 estimated to have around 500+ bhp
Re: half done suspension
« Reply #10 on: 30 December 2009, 23:32 »
yep got the rubber bushes, and got item number 5 from the old shock so ill put that on the new shock as ive left it off atm  :embarassed: item number 5 is giving me some hassle as when i put that on the top f the shock it means not enough thread comes through at the top actaully in the car where the bushes and top mounts are is there a technique or should it just slide in like usual?
Ill attack it again tommorrow and hopefully will have some better luck!
Thanks for all the help guys, really appreciate it!!!
« Reply #11 on: 30 December 2009, 23:38 »
You don't need number 5, the one on the coilover replaces it.
Offline hyland770
« Reply #12 on: 30 December 2009, 23:52 »
BRILLIANT!!! that means ive done it correctly at the back!!! Cheers wayne you just made me one happy bunny!
Wheres a good place to jack the front up btw?
« Reply #13 on: 30 December 2009, 23:55 »
Under where the subframe bolts, look under the car just behind the wheel.
