Author Topic: AEX to ABF Conversion  (Read 2239 times)
Offline sop101
« on: 22 December 2009, 20:25 »
Hi, just wondered if i could gain some extra knowledge on parts needed for the swap. Its a 1997 mk3. Got hold of an engine, engine mounts, manifolds, airbox, all ancillaries, downpipe, exhuast system, loom, ecu and fusebox. Going to buy 16v clocks.
Just wondering whats the best gearbox to get. Is it best to get a mk3 8v gti gearbox or a mk2 16v gearbox? When doing the swap whats the situation with the flywheel and clutch? Do i need to change to match the gearbox? Is there any other gearboxes that will fit?
I also have bought an uprated suspension kit and know i need to get bigger brakes. I want to keep the 4 stud wheels i have on it so is the corrado 16v or mk2 16v hubs a straight swap? or will i need wishbones also. I also have heard the arb i have got on mine will cause an issue with where it sits so will i need to change that also? Do i need to change anything for the power steering?
I know theres lots of questions but i would rather check on everything before i dig into it.
Thanks for the help  :wink:
Offline VR6-Joe
Re: AEX to ABF Conversion
« Reply #1 on: 22 December 2009, 20:28 »
Why not use a Mk3 16v gearbox (which is suited to the engine anyway!) and convert your car to hydraulic clutch and cable change?
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline sop101
« Reply #2 on: 22 December 2009, 20:32 »
i assumed this would be a complicated process and i havent really looked into it. The only reason i havent looked into it is because it means i will have to spend more on new parts but if its not that expensive and the swap is pretty simple then i have no issues
« Reply #3 on: 22 December 2009, 20:37 »
The swap is not that simple, everything needs changing to be honest.
Plus one has to ask why build what you can buy.
Offline Jimp
« Reply #4 on: 22 December 2009, 20:55 »
He's already bought most of what he needs, may as well build it at this stage  :grin:
Not low enough mk5
Not on the road enough mk3
« Reply #5 on: 22 December 2009, 20:56 »
Fair point but it is still the hard way to do it with starting with a small engine car.
Offline VR6-Joe
« Reply #6 on: 22 December 2009, 21:08 »
Plus if you're going to do all of that then you might aswell just chuck a VR lump in instead of the ABF
Offline sop101
« Reply #7 on: 22 December 2009, 21:28 »
I want to stick with the abf route. do you have any info on the stuff i asked about?
Offline boneybradley
  • Back in a Mk3...
« Reply #8 on: 22 December 2009, 21:28 »
check lazylunatics thread in dubrides/projects as he's used a std mk3 (although fitted a 1.8t) but he can help with gearbox,clutch,suspension and brakes as he's still 4 stud
  • Back in a Mk3...
« Reply #9 on: 22 December 2009, 21:29 »
