Author Topic: what have i done?  (Read 4402 times)
Offline weazgti
Re: what have i done?
« Reply #10 on: 23 December 2009, 08:34 »
I did a search and could nt find anything that says disconnect battery before removing ecu.
I will be venturing outside in a mo and hopefully its something really silly like i ve damaged a pin or something
Offline JC
  • Back in the North.
« Reply #11 on: 23 December 2009, 08:36 »
I believe Khare is spot on and you have fried the ecu.
or fudged it as posted earlier  :wink:
Offline weazgti
« Reply #12 on: 23 December 2009, 09:35 »
Just been out and it fires once every now and again but then the relay goes crazy and stops it. Took plugs out and spun it over,no fuel come out and then my battery died trying to start it so looks like ill be getting a bus to go get my wifes car to jump start.
Offline weazgti
« Reply #13 on: 23 December 2009, 11:44 »
started with jump leads relay stopped clicking after a while then it started. soon as i tried without the leads on it started clicking for a bit then starter gave up and just spins not turning over engine.can it get any worse.
« Reply #14 on: 23 December 2009, 11:55 »
You may have filled the bores with petrol.
Offline weazgti
« Reply #15 on: 23 December 2009, 12:19 »
no checked that and just got it running by hitting the starter. It starts and runs on its own now just every now and again the relay clicks once and the engine surges
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #16 on: 23 December 2009, 12:24 »
sWAP OUT THE RELAY-THEY ARE A COMMON FAILURE, AFTER ALL!
Caps, sorry!
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline weazgti
« Reply #17 on: 23 December 2009, 13:41 »
am off to get starter and relay. thanks for that didnt know they were common fault.
Offline weazgti
« Reply #18 on: 23 December 2009, 17:35 »
got relay off a mate but does same thing.water in fusebox maybe? just gonna leave it till after christmas now and get new relay aswell as pulling the fusebox down.
Offline Jay
  • balding fat cvnt
« Reply #19 on: 23 December 2009, 18:04 »
new ECU  :lipsrsealed:
