Author Topic: changing the battery  (Read 742 times)
Offline mar_k
« on: 19 December 2009, 12:22 »
i was under the impression that if the battery is removed ill need to put the radio code in after.
ive just replaced my battery a couple of hours ago and was worried since i dont have the code.
after connecting the terminals i tried the radio and it said 'safe' then showed '1000' on the display.
after 1minute the radio came back on and works.
was i just lucky?
Offline northeast_gti-t
  • "1.8T AGU"
Re: changing the battery
« Reply #1 on: 19 December 2009, 17:08 »
if you have the oem factory fitted unit then no code will be needed if the battery is disconnected at anytime  :wink:
2000 Mkiv GTi 1.8T AGU
Offline mar_k
« Reply #2 on: 19 December 2009, 18:30 »
ok cool, thats good to know
