Author Topic: on motorway no pwer at all  (Read 31920 times)
Offline Adam
Re: on motorway no pwer at all
« Reply #60 on: 10 February 2010, 11:05 »
Glad the N75 code has gone.
16686 - http://wiki.ross-tech.com/index.php/16686/P0302/000770
18075 - http://wiki.ross-tech.com/index.php/18075/P1667
I wouldn't have thought it has anything to do with the vacuum system. It's an injector problem. Have a read at the links above.
Have you got access to Vag-Com? if so read blocks 08, Group 18. Should be 0 at idle and all should raise to the same and fall the same. You might just get away with replacing the harness but then again may be the injector. Have you run some injector cleaner throught the system? Worth a try, give Millers Diesel Cleaner a go.
« Last Edit: 10 February 2010, 11:07 by Adam »
Down Hill From Here.
Offline nadlad
  • Building Surveyor MRICS
« Reply #61 on: 10 February 2010, 12:32 »
injector loom to cylinder 1 is f**ked u need a new loom 40 quid vw
<<<Big Build Thread>>>
Offline Adam
« Reply #62 on: 10 February 2010, 13:54 »
Sure it will be cylinder 2.
Offline nadlad
« Reply #63 on: 10 February 2010, 15:03 »
usually cylinder 1 makes the car work on 3 cylinders hence why it sh!t its a common fault
Offline Adam
« Reply #64 on: 10 February 2010, 16:29 »
The codes he has been getting relate to a cylinder 2 misfire and pump problem.
Offline vw-8v
« Reply #65 on: 10 February 2010, 19:40 »
so how about i get all 4 done at same time?
vw quoted me £49.27 including vat for the whole loom well i think so part number 038971600
or as suggested could i just get cyclinder 2 and one? as makes sence to get them all done.
could i do it myself? and step by step guides?
if not how much in labour you reckon (vw)? as i cld get harness and go to a vw specialist this next port of call looks like and i gonna get some of the innotect turbo cleaner of ebay to give it a clean out.
lol adam yeah we getting there lol  (yeah i looked at that code site ages ago when someone maybe yourself posted to look at it hance i had info for codes on an old post on this thread) but if i saw this thread i wouldnt read it ha ha ha its too too long ha ha ha.
Offline Rhyso
« Reply #66 on: 10 February 2010, 19:55 »
that loom is for all the injectors not individual ones  :smiley:
should be no more than a couple of hours work i would have thought  :undecided:
Offline vw-8v
« Reply #67 on: 10 February 2010, 20:03 »
is it def a vw or specialist job? or can it b done on the drive????
any info on procedure?
will call vw tomorrow for quote for all getting done.
Offline Rhyso
« Reply #68 on: 10 February 2010, 20:09 »
any one with a basic mechanical knowledge should be able to do it
I've never done it so can't give you any info on how to do it
Offline nadlad
« Reply #69 on: 10 February 2010, 22:05 »
onw injwctor is over 230 quid whats teh point when all u got is a f u c k e d wire
