Author Topic: decent mid range suspension setup  (Read 6594 times)
Offline Tucker
Re: decent mid range suspension setup
« Reply #20 on: 21 October 2004, 09:02 »
Mine has been dropped 40 on 15's, no rubbing or anything, not sure what with tho as it was done before I got the car, nice ride to :P
http://i10.photobucket.com/albums/a109/sydney04/mk116vsmallpic.jpg
Sig too large, see forum guidelines - Admin.
Offline Gambit
« Reply #21 on: 21 October 2004, 09:45 »
do not go lower than 30mm. u want the wishbones to be as near to the horizontal as possible - otherwise it f**ks up the handling
Eibach 25mm are as close as you can get to the horizontal
Koni Yellow's/ Eibachs & Eibach ARB's along with braces will make a car go rounds corners like it is on rails. and also be more than driveable on normal roads.
also, keep an eye out for et25 alloys. they help widen the track a little and make it a bit more stable
Offline Adam-D
« Reply #22 on: 21 October 2004, 09:54 »
so eibach 25mm springs
set of strut braces
and koni yellow shocks
sounds like a list ;D
dunno what ofset my current wheels are  ???
Offline Gambit
« Reply #23 on: 21 October 2004, 10:37 »
put ARB's on your list. these are an essential
Offline Adam-D
« Reply #24 on: 21 October 2004, 10:54 »
opps missed em out lol
set of strut braces
eibach arb's
are they called koni yellow or do they have a diff name?
Offline Gambit
« Reply #25 on: 21 October 2004, 11:22 »
yeah they are known as Koni Yellow. they are fully adjustable
keep an eye out for Bilstein fully adjustables also, they are just as good
VeeDubGTI16v
« Reply #26 on: 21 October 2004, 14:13 »
you have to get the rears for a corrado if you want the top adjustment ;)
Offline philadams16V
« Reply #27 on: 21 October 2004, 14:26 »
I'm interested in uprating the suspension on my 16 valver.  So its the corrado rear koni yellows that are required for adjustment not golf? And wot about the fronts?  Also wot are eibach arb's ?  Cheers
Offline Alexg40
« Reply #28 on: 21 October 2004, 23:41 »
You cant expect to lower a car 100mm on coilovers and retain ride quality. It just isn't going to happen. There simply isn't the travel in the springs to cushion the bumps.
I dont expect to be able to nail my 16v everywhere I go, it's a trade off against the look that I want to achieve.
On uprated ARBs, I would say that in my experience, anything that reduces body roll is a double edged sword....yeah in the dry your car will handle like it is on rails, but in the wet you are on a knife edge and you better have quick reactions because when the back decides to let go you aint gonna have felt it coming.
I have to drive my 16v extra cautiously in the wet. Again, it's a trade off.
For everyday use and fast road driving you can't beat a Koni/Eibach set up for value and performance. That's what I use on my G40 and it handles awesome (no mean feat for a Mk3 Polo) and a few mates use the same set-up on Mk2 GTI with excellent results.
