Author Topic: Throttle cable grommet  (Read 826 times)
Offline Dave_IOW
« on: 14 December 2009, 18:45 »
Ok, so after reading and trying many numerous different methods of getting amp cable / boost gauge vacuum hose into interior, it has come down to the throttle cable grommet.
Only problem is, this grommet does indeed have my throttle cable running through it  :tongue:
Is this possible (and safe) to cut open grommet and poke through my amp wire and vacuum hose, these will be the only things running through and amp wire will be 4awg i think.
Opinions please
Have tried one behind pollen filter, and running through door, neither of which i can do.
Thanks
Dave_IOW
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline dai-cymru
  • 1989 MK2 16V
Re: Throttle cable grommet
« Reply #1 on: 14 December 2009, 19:04 »
personally i wouldnt run a power wire next to the throttle cable as it could chaff through, drill a hole on the passenger side and you can buy grommets, tif you do run it through the throttle grommet put some silicone around it after to keep the water out  :smiley:
Offline Dave_IOW
« Reply #2 on: 17 December 2009, 18:03 »
Sorry to resurrect but can anyone shine any advice? just want this sorted so i can hook boost guage up to see whats happening?
