Author Topic: Wheel Spacer Sizes  (Read 1603 times)
Offline DYL4N
Wheel Spacer Sizes
« on: 13 December 2009, 16:36 »
Right, im thinking of making some wheel spacers.
Has anyone got the wheel spacer size's? Diameter, from nut to nut etc etc.
Im thinking of starting doing the 5 - 15mm spacers.
These should be much cheaper than the ebay ones.  :smiley:
Golf Mk4 1.8T
Ko3s Turbo
Front Mounted Intercooler
Lighted and balanced flywheel
Stage 1 Re-Map
Lowered 40mm
18'' Rs4 Wheels
Offline troublestarter
Re: Wheel Spacer Sizes
« Reply #1 on: 13 December 2009, 16:42 »
if you want to do them for a mk4 golf then they are 5 x 100 pcd
centre bore will be 57.1mm if you are going to make them properly and make them hubcentric
you need to consider the cost as you can get them on ebay delivered in 15mm (as i have ) for £53
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline DYL4N
« Reply #2 on: 13 December 2009, 16:55 »
They should be cheaper than that.
Golf Mk4 1.8T
Ko3s Turbo
Stage 1 Re-Map
Lowered 40mm
18'' Rs4 Wheels
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 13 December 2009, 17:00 »
I sell hubcentric pairs in 5x100/5x112 multifit 10mm for £40... but if you have to ask dimensions, not being a cnut but it sounds like you're already out of your depth a bit
Offline Grand Master Patch
« Reply #4 on: 13 December 2009, 19:28 »
Chris-can you get your hands on adapters?
Offline jonnyturbo
« Reply #5 on: 13 December 2009, 19:31 »
I got 20mm hubcentric ones with bolts for £55
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 13 December 2009, 23:32 »
no mate, i have a rule about not selling stuff i'd consider unsafe on my own car :grin:
« Reply #7 on: 14 December 2009, 21:34 »
Safe as houses,the old skool owners have been running them for years,my current rear spacers are of the adaptor type :undecided:
Offline topher
  • Administrator
  • fully functioning
« Reply #8 on: 14 December 2009, 22:14 »
It's probably just me being paranoid. Sure they're fine on oldskool aircooled stuff, and on rears, but 250+ lbfts through bolts of unknown grade doesn't fill me with confidence. I'd panic and pull over every time i hit a pot hole at speed :grin:
« Reply #9 on: 14 December 2009, 22:54 »
I know what you mean,but some barmy bar stewards run 5mm spacers up front without longer wheel bolts,this is far more dangerous imo :laugh:
