Author Topic: Finally found the cause of my boost problems  (Read 18700 times)
Offline topher
  • Administrator
  • fully functioning
Re: Finally found the cause of my boost problems
« Reply #60 on: 13 December 2009, 15:55 »
Errr.. might be actually. I'm sure I saw something in the diary over that way. Just get him to check every little pipe that sits under the inlet manifold. Could even be a pinhole but if there is any sign of wet/oil/muck/buildup around those pipes then something is leaking down there.
Offline dai-cymru
  • 1989 MK2 16V
« Reply #61 on: 13 December 2009, 16:07 »
hello chaps, already checked the small pipes down under the inlet manifold cant see anything obvious  :sad: but could be a pin hole as you said  :undecided:
if you can get it here we can have a look mate no problem at all :cool:
not in South Wales any time soon then  :tongue:
No doubt Dave will see this and reply as to what he wants to do; his time is pretty limited at the moment between new baby and fitting stuff to my car work
yep got to helicoil a sump, refit a v8  disco starter, fit the tip fit some shocks to somebodys tdi  :wink: and thats not including my shifts and stuff ha ha
Offline richw911
« Reply #62 on: 13 December 2009, 22:50 »
Pancake pipe the small join one under the bumper?  :undecided:
Offline Rhyso
« Reply #63 on: 14 December 2009, 07:58 »
fixed that one
Offline dai-cymru
  • 1989 MK2 16V
« Reply #64 on: 14 December 2009, 19:10 »
right standard tip is back on (although i have an extra hole (ba-boom  :wink:) on this tip that i had on the forge but not the original tip that came with the car)
It goes like stink  :smiley: but need to clear the codes and run it for a few days to know if it's cured anything as it's an intermittant fault anyway and can take a few days to show up.
Forge TIP now for sale http://www.golfgtiforum.co.uk/index.php?topic=137715.0
Offline Grand Master Patch
« Reply #65 on: 14 December 2009, 21:02 »
so if he's doing the test wrong is anyone going to enlighten him on how he should be doing it?  :undecided:
By not blocking off the hockey puck your pushing boost into the crankcase,this isn't recommended as your putting pressure into parts of your engine that are never under boost.You'll find leaks at your dipstick,but this isn't and will never be a boost leak.
The only real way imo to test for a leak in your boost hoses is to fit a tester onto the charge pipe just after the turbo.
Offline topher
  • Administrator
  • fully functioning
« Reply #66 on: 14 December 2009, 21:12 »
Thats why most leak testers only use about 5psi.. perfectly safe and shows leaks in the pcv system that you'd probably never find otherwise
« Reply #67 on: 14 December 2009, 21:16 »
Just get rid of the whole lot.
My tip held 18psi without any worries,you did yourself proud fitting it :wink:
« Last Edit: 14 December 2009, 21:20 by Grand Master Patch »
Offline dai-cymru
  • 1989 MK2 16V
« Reply #68 on: 14 December 2009, 21:18 »
which bit is the hockey puck?
« Reply #69 on: 14 December 2009, 21:23 »
The PRV that looks like a hockey puck is attached to the tip next to the N75.
