Author Topic: how do i lock the flywheel?  (Read 1302 times)
jamie16v
« on: 09 December 2009, 17:04 »
http://www.golfgtiforum.co.uk/index.php?topic=137287.0
i know its a double post but im desperate and its relevant to both categorys.. :nerd:
Offline Waffs1984
  • Spacers are for chumps...
Re: how do i lock the flywheel?
« Reply #1 on: 09 December 2009, 17:32 »
Hi,
I have not actually done anything to do with clutch/gearbox on my golf but i have done of various other cars i have owned in the past...
Basically you want to be looking for a hole in the gearbox casing (usually "bell" shaped) that you can insert a piece of high strength steel in (like a peg - i have used the plain part of a drill bit before). There is a corresponding hole in the flywheel and you will have to find out what position to crank the engine to (by hand) which i imagine will be in the Haynes manual, although its usually "cylinder 1 to TDC". You could do trial and error by getting a mate to gently turn the engine over by hand whilst you gently push whatever you are using as a peg inwards - it will slot in all of a sudden and you have found your hole as it were...
I would recommend putting bright red tape or something around the "peg" once installed so you cannot forget to take it out afterwards. If you try to turn the engine over with the key and the peg is still in it will be bye-bye for various components!
Hope this helps and that VAG engines are not massively weird or different to any others out there  :wink:
Mk4 GTi-T AUM l R-Tech Stage 1 l AP Coilovers l Forge 007p l New Style RS4's 18" l Toyo Proxies 4 l Hofele Bumper Grills l Silver Interior Trim l N249 Bypass l Front & Rear Powerflex bushes l Forge TIP l CAI l GolfGTi.co.uk Stickers l Catch Can Fitted & PCV System Deleted l Redstuff Rear Pads l More to come...
jamie16v
« Reply #2 on: 09 December 2009, 19:03 »
 :tongue: did it with a bolt and screwdriver against the teeth method, i also cleaned and greased the starter motor while it was out  :smug:
Offline dai-cymru
  • 1989 MK2 16V
« Reply #3 on: 09 December 2009, 19:07 »
yeah just done this method on my tdi, put 2 of the g/box bolts back in jam the screwdriver in,  or have you got access to a battery gun?
« Last Edit: 09 December 2009, 19:10 by dai-cymru »
jamie16v
« Reply #4 on: 09 December 2009, 19:16 »
i have a compressor and air gun :smug: lol didnt work too well though  :undecided: the screwdriver method seemed to do the job well without cutting my knuckles lol.
 only thing bad i have done is snap both 13mm bolts on the dogbone mount  :drool:. oh, dear
Offline dai-cymru
  • 1989 MK2 16V
« Reply #5 on: 09 December 2009, 19:27 »
quite common that, i take it you mean the 2 13mm headed ones?
jamie16v
« Reply #6 on: 09 December 2009, 20:52 »
yep, and the mount dont want to budge, any suggestions?
Offline dai-cymru
  • 1989 MK2 16V
« Reply #7 on: 09 December 2009, 22:12 »
going to have to get some heat onto it, careful not to heat the rubber up or you will have a fire, or you can cut the mount in half and cut the centre out  :smiley:
jamie16v
« Reply #8 on: 09 December 2009, 23:38 »
cheers dai!
