Author Topic: so fed up.  (Read 3377 times)
jamie16v
Re: so fed up.
« Reply #10 on: 09 December 2009, 14:31 »
it`s a right sh!tter and to top it off i have now snapped the head off one of the bolts which hold the dogbone to the subframe  :cry:
Offline Rhyso
Re: so fed up.
« Reply #11 on: 09 December 2009, 14:34 »
arse  :sad:
they are only a couple of quid from the dealer but whether they have them in stock or not is another matter  :undecided:
jamie16v
Re: so fed up.
« Reply #12 on: 09 December 2009, 14:35 »
arse  :sad:
getting the remainder out will be the fun part  :drool:
Offline richw911
Re: so fed up.
« Reply #13 on: 09 December 2009, 17:23 »
can I join your club?
A week can't seem to go by where another problem doesn't arise  :angry:
Whats wrong with you know mr Rhyso?
not holding boost on full throttle  :undecided:
Dam sorry to hear that bud  :cry:
What are you going to do smoke test?
Offline tg1
Re: so fed up.
« Reply #14 on: 10 December 2009, 10:30 »
No point, Its a diesel of course it'll smoke  :laugh:
Offline Rhyso
Re: so fed up.
« Reply #15 on: 10 December 2009, 10:50 »
har har  :tongue: not as much as you think
tis a strange one in that in 4th gear it drops to 22-23PSI yet 5th gear holds 24PSI  :undecided:
Offline tg1
Re: so fed up.
« Reply #16 on: 10 December 2009, 10:57 »
I'm sure rtec said why something like that happens in, the january meet thread
Offline Rhyso
Re: so fed up.
« Reply #17 on: 10 December 2009, 11:01 »
I'm sure Nick said he wasn't sure when i spoke to him yesterday  :tongue: :grin: :grin:
I know 1st, 2nd and 3rd gears you will never load the engine enough to see that sort of PSI maintained but 4th onwards should do   :undecided:
Oh well - new suspension is on the cards and it drives fine at the moment; we'll see in January if i got a problem but I know that my car will be run in 5th gear so it should be fine  :grin: :grin:
Offline tg1
Re: so fed up.
« Reply #18 on: 10 December 2009, 11:30 »
ok maybe i wasn't sure then  :grin:
thought about trying 10k boost for dervs?
or maybe a tiny tiny boost leak? but i guess it'd show in 4th as well?
Offline Rhyso
Re: so fed up.
« Reply #19 on: 10 December 2009, 11:39 »
or maybe a tiny tiny boost leak? but i guess it'd show in 5th as well?
10K boost? What's that?? Like an octane booster equivalent?  :huh:  I run Forte diesel treatment through every now and again and also only use Total Excellieum diesel which is full of a few extra additives designed to keep everything fairly clean; also means I get at least another 40 miles out of a tank  :smug:
If it was a boost leak I'd expect to see it in all gears  :undecided:
