If anyone still reading this please help!
Golf remains firmly stuck at local garage, Idle improved from so far changing:
HT leads
Plugs
Dizzy Cap
Rotor arm
ECU relay
Coolant Temp switch
Vacuum pipes checked
and wiring seems ok
Car still 'hunts' slightly (around 850-900) on Idle and when cold feels like it will easily stall.
When driven car still not pulling well from low revs, cars 'bogs down' then pulls fine at higher revs, this happens in all gears.
Need some advice as to what next- car diagnostic throws up Lambda, this was changed around 12 months ago, don't know whether it could have failed again? Or is it the MAF sensor, even though not showing codes?
Any help greatly appreciated, running out of money and patience and getting bit depressed about the whole thing!
Cheers all
