Author Topic: Coolant Flush on 1999 AGU lump. Some stoopid questions :)  (Read 11796 times)
Offline dai-cymru
  • 1989 MK2 16V
Re: Coolant Flush on 1999 AGU lump. Some stoopid questions :)
« Reply #10 on: 05 December 2009, 21:37 »
wasnt far off with -40 then  :wink: personally i would do 2:3 we are never likely to see -24  :wink:
Offline topher
  • Administrator
  • fully functioning
« Reply #11 on: 05 December 2009, 21:41 »
2 bottles of G12++ so 3L then 2L of that water. Would that be right? Then fill the whole system using that?
Stick with that plan, although you probably wont use it all as you can't drain the entire system. That way you can do top ups with water without worrying about diluting the mix too much.
