Author Topic: N146??  (Read 4669 times)
Offline northeast_gti-t
  • "1.8T AGU"
Re: N146??
« Reply #10 on: 04 December 2009, 21:09 »
Thanks for that matey  :grin:
If its the injection pump its more like the scrappage scheme for a mk6 or a scirocco!
And if its the solenoid its more like in the pocket from the scrappers!!  :evil:
the fuel pump has two solenoids the top one is the fuel cut off one and looking again you may require the one at the rear which etka says (180mm)wiring harness so i think that is correct
part number 028 906283 M (180mm harness)
                 028 906283 M (300mm harness)
both for inj pump 038 130 107 B & D
no problem hth
mk6 or scirrocco sounds good  :wink:
2000 Mkiv GTi 1.8T AGU
