Author Topic: 6x9" speakers in shelf supports??  (Read 2900 times)
kniterider
« on: 11 October 2004, 14:16 »
as above, now ive got a standard rear shelf again,  has anyone mounted 6x9 's in there support bits?? mk2...
Gaz
free
Re: 6x9" speakers in shelf supports??
« Reply #1 on: 20 October 2004, 22:51 »
u mean the sanderd speaker hole?
Offline jv
  • Administrator
« Reply #2 on: 20 October 2004, 22:53 »
you would have to go some, not sure they are even wide enough. could always not bother, have some good components up front and a sub in the boot
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline Dizzie
  • Make friends with your fast
« Reply #3 on: 20 October 2004, 23:29 »
that's all I'm running. 13cm's in the doors and tweeters in the dash off the headunit and a 10" JL sub off the Genesis amp in the boot. Sounds sweet and clear as can be. I didn't even notice a difference when I disconnected the 6x9's.
(nice avatar btw Gaz  ;))
Mk4 Golf 150PD
Offline jasonpi
« Reply #4 on: 28 October 2004, 21:25 »
hey gaz u ?and mrwotto got ur own personal airstrip, coz everytime i see a golf in ur sig its there ????
Offline lints
« Reply #5 on: 29 October 2004, 10:19 »
very much doubt 6 x 9's would fit, try holding one under and i doubt theres is enough clearance. you'd have to build a mdf spacer also to fit it to the support to allow the cone to move.  id stick with 6 x 4's if your using those mounts.
