Author Topic: Water in Engine...  (Read 2382 times)
Offline Scottie33
Water in Engine...
« on: 04 December 2009, 09:17 »
Hi chaps, our Golfs poorly, we think its gradualy sucked up water from its induction kit which was located down in the wing & since monday has run like a bag of nails, keeps cutting out & loads of white smoke out the back when you try to rev it.
Ive taken the I/K off now and replaced it with a orginal item (thanks stevens breakers), took maf off, plugs out etc to dry them abit. Wasnt too much there but still dont know what else to do, my dad has given us his little runaround to use so Golf is just sitting there now,  :cry:
What do you guys advise?
Please help a newbie
For Sale : Induction Kit  :rolleyes:
Offline vwprime
Re: Water in Engine...
« Reply #1 on: 04 December 2009, 10:52 »
Do you remember going throught any large puddles or water when driving?
Is it a 1.8T? If so take the intercooler off and see if any water comes out if there as some might water might be sitting in it.
Does the oil look ok? Is theres any water in there? What coilout is the smoke out the back? Is it white or a whitey /blue colour?
Where about are you in the UK, as some one on here with Vag Com might be local to you who can plug in and see if its just a falty sencer or somthing.
TRANSFORM, & ROLL OUT!
Offline jake
« Reply #2 on: 04 December 2009, 10:54 »
If you have got water in the engine that is NOT GOOD at all
Some people like to call it (hydro lock)
Basically the engine cannot compress water and causes serious damage either to rods or pistons! If its smoking it could be rings! Is it buey/white smoke?
Or it is possible that the intake of water has knocked out the timing! i.e. the car is running sh!te because the timing is now out! i..e your valves and movement are not in order!
My induction kit is the Carbonio kit and that sits near the floor in the wing, theses are lethal in reagards to water!
Are there any knocking noises coming from the engine? I.e towards the bottom end?
Jake
Offline Adam
« Reply #3 on: 04 December 2009, 15:57 »
As a wise man once said your con rods will look like bananas
Down Hill From Here.
Offline bobbarley
  • I'm kind of a big deal...
« Reply #4 on: 04 December 2009, 16:01 »
Not sure how to remedy the solution, but going forward stick to the proper airbox, and put a better panel filter in it  :smiley:
Offline AlanD
  • MK5 2.0T 16v
« Reply #5 on: 04 December 2009, 16:19 »
In the words of Vinne Jones "This will get messy" :(
Offline DaveSurf
  • 20v 1.8 T
« Reply #6 on: 04 December 2009, 16:54 »
Mate of mine drove through a flood (ford) with a low level induction kit on... pushed out lots of black smoke and wouldnt start after.  Got the AA out to it fearing the worst, but the guy took out the spark plugs and used a squeezy bottle type thing (with a long tube and kind of trigger gun at the top) to get the water out. Tube down below the spark plugs and sucked out the water.
His car seemed to work fine after!
FOR SALE - Mk4 Golf Gti Reflex Silver 5 Door £2400 ono ***new price *** - OPEN TO OFFERS (see for sale section)
Sleeper - tweaked by R-tech and goodies from Forge!
Offline Scottie33
« Reply #7 on: 04 December 2009, 19:24 »
Its going in next thursday to have a compression test done & we're going to take the intercooler off to see if theres any water in there. Best to start with the simple things.
Thanks for the replies, will keep thread updated
Scott
 :cry:
Offline Scottie33
« Reply #8 on: 10 December 2009, 14:42 »
Had a compression test done at my local VW dealer today & it came back fine : 1) 9.7 2) 9.6 3) 9.3 4) 9.5 bar.
We havent started / drove the car since last thursday but took it easy only giving it abit of welly once I was nearly there just to see & all was good. On the way home I drove it quiet hard, again just to see if there were any side affects but it looks like all is fine & only needed time to dry out.
Will keep my eye on it tho & will tell the wife to take it easy the next few weeks - just in case!
Thanks everyone,
Scott.
 :smiley:
Offline Rhyso
« Reply #9 on: 10 December 2009, 14:46 »
WOW!!  :shocked: :shocked:
That's well lucky!!!!!!  :shocked: :shocked:
