Author Topic: Horror stories  (Read 14607 times)
Offline jamie_ledzep
Re: Horror stories
« Reply #10 on: 09 December 2009, 23:57 »
you cant start a thread like this and say ''ill let you know whats going on one day'' !!
 :huh:
Offline spoolking
Re: Horror stories
« Reply #11 on: 10 December 2009, 13:14 »
Hey,..
 So ive been I contact with Nick a couple of times since I had this problem. I phoned Nick today with the intentions of finding out why and what happened with an added bit of attitude to compensate the grief and stress that I have had to endure due to the current predicament. As much as I would have like to say f**k you, you caused this, after haven spoken to him twice I have come to realise as hard as it was to except that I was the cause of this problem or at least thats how I feel right now(maybe ive been Duped).
 Nick gave a detailed explaination to why it happened and as much as I wanted to pipe up down the phone there really seemed no need as the more he explained things.. At the same time most of it was common knowledge and some, Not all i already knew.
 I surgest that When you do take your golf to a mechanic do so to one that knows alot about the Engine after all i did take it to a guy before this all happened who failed to find the root of the problem or so im lead to believe. Maybe it was just me being a dumb ass (ouch pride) but im taking a valuble lesson away. Take Notice of what your engine is saying to you and get it looked at stright away. Im aware that most of this is common sense but i consider myself some what of a smart guy and i still got burnt and Im definately not going to be the last guy either.
 :cry: :cry: :cry:
I have just spoken to my mechanic a trusted one who will also ring Nick today and just to comfirm that what i believe or have been told is truthful.
http://i303.photobucket.com/albums/nn142/RichardCV/DSC00237.jpg
http://i303.photobucket.com/albums/nn142/RichardCV/DSC00241.jpg
« Last Edit: 10 December 2009, 13:54 by spoolking »
Offline Horney
Re: Horror stories
« Reply #12 on: 10 December 2009, 13:47 »
Modifying cars is always risky as you're putting more stress on components than they were designed for. A careful and considred approach most of the time rules out problems but there is always the possibility of a weak link in the chain. And sometimes stuff just fails through no ones fault.
It sucks and I'd be angry if my car went bang, it's only natural and it's hard thing to deal with when it's not only your beloved hobby but your transport as well.
A mate of mine has a very good saying that might cheer you up. "If it's not broken, it's not modified enough." :grin:
nick
Offline Rhyso
Re: Horror stories
« Reply #13 on: 10 December 2009, 13:54 »
its never nice when things go wrong with your car and in the heat of the moment you'll always find someone to blame, in most cases, it will be the last person who touched your car
We've al endured problems and hardship with our cars and people deal with problems in different ways
Big up to yourself though for having the guts to admit it could possibly be down to you  :smiley: and not just going on a one man rant wave against all and sundry  :laugh: :laugh:
Sadly you've learnt the hard way but lets hope it doesn't put you off modifying any future cars  :smiley:
On a side note my mate Dave has a 1.8T turbo for sale...... :tongue: :wink: :smiley:
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: Horror stories
« Reply #14 on: 10 December 2009, 15:49 »
Hey,..
 :cry: :cry: :cry:
Hello Mate,
I have just spoken to your mechanic who is fixing your car, he now says its only 1 piston gone down? not more as suggested the other day?   It will be cheaper to change just that piston? or has the bore been damaged aswell?
Number4 piston is the last in the line when it come to fuel delivery in terms of the way the fuel rail works which means its the first to fail when lean conditions set in.
IMO defo a lean fuel issues still caused the piston to melt as it has,  You said you was well in to the red line close to 7000rpm on the dual carraige way, in the mapping the soft cut limiter is set to 6800rpm in the map you have on your ecu, what happens when the limiter is reached the ecu cuts back the fuel and load request to bring the rpm back down to the mapped limit of 6800rpm then start to load and fuel again, this can also cause lean issues and hot piston crowns & spark plug tips put normally not cause a piston to melt unless the rail pressue is not up the scratch, because if a leak pump, clogged filter or split on the fpr vac line.
Once the car is up and running again you need to get if fully check out by someone who can do logging on all the outputs and make visual picture of the reading.  Bring the car down to us and I will check it all over for you on the dyno, I will educate you and show you exactly what is going on under the bonnet, I will show you how fuel scales vs boost, I will show you how lambda effect engine temps, It should be a fun for you seeing how the intense diagnostics is carried out, plus if your planning on getting vagcom I will give you a crash course lesson on how to do a data logging session amd make USE of all the number ect..   If money is an issues dont worry you can sort us out when you have replenished you saving at a later date.
Dont lose faith in the remap or car mate, I am 100% sure once you fully under stand whats going on and you have a vagcom lead it will never happend again... The harware in your engine is good enough for 300+BHP all day long and turbo is good for 240bhp max, with the fuel safe at a 250+bhp.. :wink: as long as the fuel is ok you will be fine, then you will be wanting to get closer to the 300bhp mark from a bigger turbo.
Keep us updated, your mechanic said he will give us a bell when its up and running, he need to invest in a vagcom lead so he can do data logging.
Nick
 01455 617233
Offline coolio
Re: Horror stories
« Reply #15 on: 10 December 2009, 16:29 »
  thats what i call good customer service  :smiley:
Re: Horror stories
« Reply #16 on: 10 December 2009, 19:33 »
Im sold.
Nick, please chip my car.  You 'd' man.
Offline RTechUK
Re: Horror stories
« Reply #17 on: 10 December 2009, 20:25 »
Im sold.
Hello,
You can email us on info@r-techpower.co.uk or call us on 01455 617233 and will can get summat sorted out for you.
Nick
 01455 617233
Offline vwprime
Re: Horror stories
« Reply #18 on: 10 December 2009, 22:38 »
What a lovely reply and great advice. I hope ever thing with you car Spoolking is sorted as its sounds like its well on the way to being done and also Nick is not only going to give you the best map he will show you exactly how he does things and what to look at when hes doing it. I hope evey thing end up being a happy ending?
Nick would you ever think about doing tutorals for people who have VAG-COM and showing them how to get the best out of it? Maybe some kind of workshop? As im shore there are people out there ( me incuded) who have it but dont know what thay are really looking at or are to frigtand at changing numbers incase something goes wrong  :shocked: Some one who could teach others what to look at, moniter,check, change etc.
TRANSFORM, & ROLL OUT!
Offline spoolking
Re: Horror stories
« Reply #19 on: 11 December 2009, 00:41 »
As far as i know mate the bore is damaged. Im going to fit the new engine and see what happens from there. I dont have alot of money and im out of work. Got a job interview tomorrow and if all goes well then i might come up and pay a visist if not then the car will defo be sold.  Ill keep you posted.
