Author Topic: DIY W8 light  (Read 3255 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: DIY W8 light
« Reply #10 on: 04 December 2009, 15:19 »
your light is on it's way to you mate  :smiley:
Offline Madmax
Re: DIY W8 light
« Reply #11 on: 04 December 2009, 18:06 »
Sounds like you should do a write up for the how to section matey :cool: . I assume it worked out a lot cheaper than buying an actual W8 light?
Yea, put a how-to up. :cool:
Is there any soldering involved for those tiny LEDs, if so count me out.  :grin:
Looks nice tho.
Offline mikemk4gti
Re: DIY W8 light
« Reply #12 on: 04 December 2009, 19:09 »
  It should of worked out costing me £1.89 as thats how much I paid for 5 led's even though I only used 2. But As I broke the light removing it I had to get a new one (from wazzzer).
 I should of taken more photo's really to do a proper how to. I soldered the joints but its not neccesary really. The led's I got came prewired, There is 3 wires going to your interior light, the brown one is earth so you need to connect the black wire from the led to this, then run a wire from your headlight switch to the red wire on the led - job done. I'll take my headlight switch out over the weekend to get apic of which wire it connects to as theres loads.
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline mikemk4gti
Re: DIY W8 light
« Reply #13 on: 04 December 2009, 19:16 »
these are the led's I used, if you look in his shop theres different colours and sizes available.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=350228635958&ssPageName=STRK:MEWNX:IT
Offline golfgar
  • Audi A6 estate/subaru wagon
Re: DIY W8 light
« Reply #14 on: 05 December 2009, 00:16 »
looks good,goin to have ago at doin this,how are the bulbs held in place?
dub268
Re: DIY W8 light
« Reply #15 on: 05 December 2009, 02:03 »
Looks spot on mate, goin to have go of mine on Monday
Offline mikemk4gti
Re: DIY W8 light
« Reply #16 on: 05 December 2009, 13:21 »
If you have a look at the link to the led's you can see they have a sort of collar so if you push them through the 3mm hole that you drill from the back then use a bit of super glue they should stay put.
Offline golfgar
Re: DIY W8 light
« Reply #17 on: 05 December 2009, 14:39 »
thought that was the way to go,just wanted to make sure,cheers  :wink:
Offline mikemk4gti
Re: DIY W8 light
« Reply #18 on: 05 December 2009, 15:09 »
I have another light now, (thanks wazzzer :wink:) So I might do it different the next time by putting the leds in the smoked lens so you can't tell there there until there on.
heres the pic of the headlight switch to show which wire to connect to
Offline alex160
Re: DIY W8 light
« Reply #19 on: 05 December 2009, 18:00 »
Was it much of a job running the live feed wire to the headlight switch from the interior lamp? Where did you run it to, through the headlining.  :undecided:
2001 Golf GT TDi  150bhp/ 250 ftIb torque  *No smoke, No poke*
Jamex coilovers, 8k HID's, 18" RS6 alloys, Pipercross panel filter. Stage 1 Revo remap.THS FR3 engine mounts, Anniversary headlamps. GTI rear spoiler, Miltek largebore decat/downpipe, Pro-speed cat back exhaust system (V6 4mo style tailpipes) *SOLD*
2002 Golf GT TDi 130. Allard egr removal kit, 18" Audi rs6 alloy wheels. Mk5 rear aero wiper.gen R32 roof spoiler, JOM coilovers, JOM heavy duty adj droplinks
