Author Topic: chassis prep for track days  (Read 10934 times)
Offline dandubgti
Re: chassis prep for track days
« Reply #10 on: 02 December 2009, 23:45 »
ahh , im totally with you now , just out of interest mate , where did u get your rear strut brace / harness bar ?
thanks mate .
VeeDubGTI16v
« Reply #11 on: 03 December 2009, 08:32 »
i got it from merlin motorsport at castle combe. its just a bit of rollcage tubing. might be worth deciding now what cage your gonna use and buy it the same diameter
Offline dandubgti
« Reply #12 on: 03 December 2009, 18:34 »
just ordered a Peter Lloyd cage , just a basic 6 point , probably will add to it , just easier to start with a basic cage already made .
VeeDubGTI16v
« Reply #13 on: 03 December 2009, 18:54 »
yeah im gonna do the same, buy all the bent tubes and add to them with straight tubes. its not hard to profile the end of a tube but bending them is a bit specialist
Offline Horney
« Reply #14 on: 03 December 2009, 18:55 »
How much that set you back?
nick
VeeDubGTI16v
Offline dandubgti
« Reply #16 on: 03 December 2009, 19:27 »
its only a basic bolt in 6 point , im gonna chop the mounting plates off the bottom of the legs and fab up a nice box section for the cage to weld to . weld all the cage together and just add bars where appropriate .
Offline Horney
« Reply #17 on: 03 December 2009, 19:32 »
I reckon it'll be cheaper to get my uncle to knock something up, even with having to drive the car down to Bodmin.
nick
Offline dandubgti
« Reply #18 on: 03 December 2009, 20:09 »
scaffold spec roll cage  :grin: if its cheap and decent , why not mate .
veedubgti16v what did u use to prep your inner arches for stich welding ? that wire grinder attachment that took your knuckle off ??
Offline Horney
« Reply #19 on: 03 December 2009, 20:25 »
He's cornish farmer who builds trailers as a 2nd income so has a pipe binder and 40 years welding experience. I'd just have to supply the right tubing and some beer!
Problem is I live in Hampshire so it's a pain getting the car down there and then getting back, then going back to get it.
Nick
