Author Topic: Nick please read  (Read 3075 times)
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: Nick please read
« Reply #10 on: 03 December 2009, 21:11 »
so nick are we all good for the 16th????
also i have asked before but how much is this rr going to cost me or is it free play time???
all the best
clive
Hello m8,
Your looking at £65 for the rr time, diagnostics, software & hardware tweaks..  To get the most power from the water/meth charge cooling, you need more ignition advance in the mapping but when not on the water/meth the timing would need to be put back, good if you was running standalone or a revo map where you can switch the timing setting at the touch of a button, ie when on water/meth mix you run the top setting, then when out of water/meth you run a lower setting.
Without the ignition mapping you will still gain power from the water/meth because you will get a denser cooler combustion which = more power.  In this case you dont need to touch your ecu remapping at all, but you need to have the water/meth injection set up right. if your using a mappable water//meth setup you can set the system to deliver the mix in a linear fasion to get the most from the mix, get it wrong you will lose power.
Nick
 01455 617233
Offline westallc
« Reply #11 on: 03 December 2009, 21:15 »
okay mate will you give it a once over aswell etc etc trying to explain to the missus why i need to spend another £65 when i only paid £250 3 weeks ago lol
i will try and get to you as early as poss what time do you open as i may leave really early to avoid traffic
