Author Topic: Locked out!  (Read 13461 times)
Offline AlanH
Re: Locked out!
« Reply #50 on: 01 December 2009, 20:40 »
(Takes a deep breath...)
OK, let's take this step by step, and compare your set-up to mine. In the MFD, I've set up my lock/unlock options so that a single press on the unlock button on the remote unlocks ALL doors and the boot. However, if I don't open a door or the boot within something like 30", then the car locks itself. A sensible precaution so that an accidental press on the remote doesn't leave the car unlocked.
Now, having unlocked the car, if I open a door or the boot, the car remains unlocked until I decide to lock everything with a single remote press. I can open and close the boot/doors any number of times, and everything remains unlocked - which (for me) is how it should be...
Now, you've said this: "I'm particularly concerned by its relocking itself when the doors are locked though, because of the potential for leaving the keys inside.  I find it difficult to believe there isn't a way of over-riding that, but I haven't found it yet."
It seems to me that you need to find a setting where everything remains unlocked until, and only until, you choose to hit the lock button the remote. In that way, you can never lock your keys anywhere within your car  as you would need the remote to do this, which is attached to the keys. Am I getting warm?
Mk7 GTD | 3-door, Carbon Grey, Keyless, Dynaudio, Pano roof.
Offline Rolfe
Re: Locked out!
« Reply #51 on: 01 December 2009, 20:42 »
Thank you for your patience.  Yes, I need to find that setting.  Since I couldn't find it just by scrolling through the MFD, I may have no option but to read the instructions....  :sad:
Rolfe.
Offline AlanH
Re: Locked out!
« Reply #52 on: 01 December 2009, 21:03 »
I'm fairly sure (although I stand to be corrected) that within the Convenience settings you can select if you want only the driver's door to unlock, the driver's and passenger door to unlock, or everything to unlock. I don't have the manual to hand, so I can't be 100% sure. I'll admit that that certain sections of the manual are badly translated from the original German, and require a Master's in Engineering to follow. Worth taking another look at the relevant section of the manual that deals with the locking options and see if that offers a solution.
Edit: as an afterthought, are you using the bottom button on the remote to unlock the car, including the boot, or just the centre boot unlock button? I've a feeling that the centre button unlocks the boot once, and once the boot is closed, it relocks.
« Last Edit: 01 December 2009, 21:23 by AlanH »
Offline p3asa
Re: Locked out!
« Reply #53 on: 01 December 2009, 22:16 »
http://www.ownerwelcome.com/
Click on either the golf or GTI then on Multi Function Display. It has a video of exactly what to do.
Offline keelaw
  • It's here!
Re: Locked out!
« Reply #54 on: 02 December 2009, 00:05 »
i knew that site was useful!
Mk6 Golf GTI 5dr, DBP, Monza Shadow, Xenons, ACC, RCD510, Park Assist, Camera, Lux pack.... and now bluetooth.... and now DSG!
Offline Rolfe
Re: Locked out!
« Reply #55 on: 02 December 2009, 19:52 »
Will do, thanks.
All I could find was various door combinations, nothing that would change the boot.  I'll watch the vid!
Rolfe.
Offline AlanH
Re: Locked out!
« Reply #56 on: 02 December 2009, 22:03 »
Which button on the remote are you using to open the boot?
Offline Rolfe
Re: Locked out!
« Reply #57 on: 02 December 2009, 22:46 »
Huh, not working for me.  No options to click.
I'm using the middle button because half the time that's the only one that opens the boot anyway.
Also, I'm trying to disable the automatic boot-locking facility completely, no patter which button I open it with.  Murphy's Law and all that.
Rolfe.
Offline p3asa
Re: Locked out!
« Reply #58 on: 02 December 2009, 23:25 »
Rolfe.
Rolfe are you referring to the video or the options on the car?
Offline Rolfe
Re: Locked out!
« Reply #59 on: 02 December 2009, 23:30 »
The video.  The comically ethnic German guy keeps exhorting me to choose what I want to learn about, but there's nothing clickable or choosable.  The options are greyed out on my screen.
Rolfe.
