Author Topic: OBD READING A FAULT!!  (Read 1091 times)
Offline bathspray
« on: 22 November 2009, 16:24 »
Hi i just put my friends OBD reader onto my 16 valve mk3 gtii (p reg) and it showed the following:
INTAKE MANIFOLD PRESSURE SENSOR  (G71)   SPORADIC - NO SIGNAL
Does something need replacing if so where is it please and what??
Many thanks
MK4 GTi TURBO (BLACK)
Offline topher
  • Administrator
  • fully functioning
Re: OBD READING A FAULT!!
« Reply #1 on: 22 November 2009, 16:28 »
mk3 16Vs have a map sensor? :huh:
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
« Reply #2 on: 22 November 2009, 18:36 »
What was the actual fault code..? how is the car running..?
Offline bathspray
« Reply #3 on: 22 November 2009, 18:44 »
the car is idling but fluctuating from 1000 to 1200 revs on stand still
cheers
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 22 November 2009, 21:22 »
leaky vacuum pipe from the intake manifold somewhere then probably
Offline bathspray
« Reply #5 on: 22 November 2009, 21:27 »
Thanks ill check it all out and get a post result on!!
Offline AntAfram
« Reply #6 on: 26 November 2009, 13:23 »
i have the same issue but it's only started hasppening since i replaced the coil and ht leads. idles between 500-1200 rpm. vagcom reads intake manifold pressure sensor
(g71). can't see any breaks in the vac pipes. what do i do now????
cheers
Offline Paul86S2
« Reply #7 on: 26 November 2009, 14:35 »
The 16v map sensor is part of the ecu. The vacuum pipe from the manifold to the ecu gives it the reading. So first idea would be to check the vacuum pipe. See if it is split, take it off and blow through it to see if it is blocked. Best course of action is just to replace it because it could be collapsing under vacuum.
Paul
Offline justalex81
« Reply #8 on: 26 November 2009, 23:17 »
antafram is my cousin and it was me that had the problem. replaced the whole vac hose and it now purrs like a dream and is now a lot smoother and faster since the coil and leads.
