Author Topic: GTI Headlight Bulbs  (Read 8415 times)
Offline AlanD
  • MK5 2.0T 16v
Re: GTI Headlight Bulbs
« Reply #20 on: 04 December 2009, 16:27 »
To be honest I'm not sure what the 499 is all about :undecided:.
However the picture they have supplied is a H7 bulbs and are identical, although I wouldn't go on the picture. Id say its a pretty safe bet that they will fit. My understanding is that there is just one bulb per HX model. the 499 might just be the long winded way of H7 which is what most people use. That is a cracking price.
I am slightly concerned by the 1 review at the bottom ? ? ? Not sure what he is on about.
:edit: a bit of Googleing has shown they will fit ;) go for it.
Offline flyingzard
« Reply #21 on: 04 December 2009, 18:30 »
Yes i was a bit concerned from such a pants review!!
Thanks Alan - i shall look foward to fitting them and actually seeing something whilst driving at night!
Offline AlanD
  • MK5 2.0T 16v
« Reply #22 on: 04 December 2009, 19:11 »
Pffft, Id ignore him. He drives a Merc, 'nuff said :D
Offline mafri
« Reply #23 on: 05 December 2009, 13:05 »
I love my Philips bulbs, great for this time of year - but am getting quite irritated by the number of drivers coming the other way who flash me thinking my full beam is on! I am beginning to wonder whether my lights are out if alignment in some way. Does anyone else have a similar problem?
Diamond Black Golf GTI, DSG, Monza IIs, Cruise, MFSW, Rear Tints and Ipod. VRmmmmmmmm!
Offline Jimp
« Reply #24 on: 05 December 2009, 14:29 »
Another mk5 driver I know with Phillips bulbs has been getting people flashing him too. Could well be the alignment as it has never happened to me. That said I should probably get my alignment checked anyway, to make sure.
Not low enough mk5
Not on the road enough mk3
Offline nick30
  • Black Edition 30 DSG
« Reply #25 on: 05 December 2009, 14:34 »
i put the osram night breakers in mine today and the philips side lights, seems good havent tried them out properly in the dark yet though. the drivers side sidelight is a bit of a slag to get out though!!  :shocked:
Offline flyingzard
« Reply #26 on: 15 December 2009, 14:11 »
Changed the main and dipped lights earlier.
Thanks for all your help. Looking foward to when it gets dark.
It may be a funny import thing (lights are on all the time) but i couldnt test the main beam properly as flicking the stalk on didnt turn them on..... Do to the light sensors know when it gets dark and only allow you to turn them on then....? Flashing the lights works fine.
I am hoping all will be fine when i drive to work and its not another trip to the stealers.....  :sad:
Offline Jimp
« Reply #27 on: 15 December 2009, 17:28 »
They could have the DRL function activated where the low beams are on dimly all of the time until (AFAIK) you turn the switch to fully on. It can be reset to normal with vagcom.
Not low enough mk5
