Author Topic: UPDATE stop messing with that bloody car UPDATE  (Read 2311 times)
Offline Alec
Re: stop messing with that bloody car
« Reply #10 on: 20 November 2009, 02:15 »
If thats the case then fair do's.
I do like going to the dealers for resale value though. If someone has made the effort to try and go to the dealers for higher quality parts then maybe it could be worth it when you come to sell it, or make a claim on the insurance?
I got a blue temp sendermajig from gsf but not got round to fitting it yet, cant argue for 6.50 ish (especially if it works as it should)
The guys also offered to look around it for me for nothing which was sound
Offline dan_apps
  • too low for british roads!
« Reply #11 on: 20 November 2009, 08:34 »
what is this hatred towards GSF? like Ben says they offer good quality parts of the same standard as you would you get from a dealer! i run loads of stuff from them and not had any issues thus far. :smiley:
Offline Ben Lessani
« Reply #12 on: 20 November 2009, 08:36 »
Lol, I think I started the hatred: http://www.golfgtiforum.co.uk/index.php?topic=133365.0
Some parts can be good - some of it is parp though, but if you stick to the OEM rated kit, you should be fine.
Offline laurenceyon
« Reply #13 on: 20 November 2009, 09:35 »
I use GSF all the time, for brakes, filters, bearings, belts, heater matrix, exhaust... You name i've probably bought it from - I've never had any problems with their products apart from a faulty water pump - needless to say from the £100's i've spent there generally i'm very happy.
I only use the main dealer for parts that are unavailable, like quite recently; heater control cables..
I wouldn't worry about using GSF many of their parts come with a warrenty anyway.
Hi my name is Laurence, I'm very much like you. Only better.
Offline Lap
« Reply #14 on: 20 November 2009, 12:26 »
What about www.vwspares.co.uk ? Their stuff seems very good value and I always thought it was OE (although I could be wrong).
In any case, I've bought a thermostat and water pump from them and it's been on there for over a year now with no issues.
VeeDubGTI16v
« Reply #15 on: 20 November 2009, 12:33 »
i find gsf good overall, but have found the senders, top mounts and mk2 lock sets to be utter sh!te
Offline Goops
  • mk2 gti 16v
« Reply #16 on: 20 November 2009, 23:07 »
Gsf thermostat is rubbish, mine was stuck! I would recommend doing the boiling water plus thermostat on a string routine to be 100% sure before it drops into ur car :)
Offline theclash
Re: stop messing with that bloody car UPDATE UPDATE
« Reply #17 on: 22 November 2009, 16:37 »
ok finally went with the vw thermostat and plastic housing got pas and alternator belts from gsf.
sh@t myself when i torqued the 2 10mm bolts for thermo housing thought i had stripped them but all good no leaks  :laugh: odd thing is when i started car the idle was higher and got the random reving back again but after taking idle screw out cleaning it and a spray of wd down idle hole shes purring like she should.
