Author Topic: UNEVEN WEAR ON TIRES  (Read 3092 times)
Offline Rhyso
Re: UNEVEN WEAR ON TIRES
« Reply #10 on: 20 November 2009, 14:26 »
can you get them for 2WD Golfs though  :undecided:  Your rear suspension setup Stink is very different from us 2WD's drive boys  :wink:
no  :sad:
I didn't think so  :sad:  Quite good as thats some money saved  :laugh: :laugh:
Offline the_stink
  • A3 140 TDI
« Reply #11 on: 20 November 2009, 15:25 »
no  :sad:
money saved? but if your camber is out and you get uneaven wear then 'said saved money' will be going on new tyres ;) its one fo those things that i had to do but saved some money only cost me shy of £300 to sort my wheel alignment out instead of 400 thank god for GB
Offline Rhyso
« Reply #12 on: 20 November 2009, 15:44 »
no  :sad:
Camber on the rear is unlikely to be out on 2WD Golfs though unless its been in a shunt or you've twitted a kerb. So ergo we are still saving money as we are less likely to have problems compared to you 4WD boys
Offline the_stink
  • A3 140 TDI
« Reply #13 on: 20 November 2009, 15:48 »
no  :sad:
always got to have the last word!  :grin:
Offline DON_GEOVANI
« Reply #14 on: 17 December 2009, 12:50 »
hiya guys, i sorted out my front tires was just the tracking was toed in too much, HOWEVER the mechanic showed me the back tires (cos there was a light humming noise like a wheel bearing) and the inside edge of the rear left handside tire is really badly worn but in a strange way all wavey and bumpy you can see it quite obviously. any ideas? its kind of sloping up and down around the tire very strange.....
Offline Mr_Orange
« Reply #15 on: 17 December 2009, 13:11 »
Yes mate, a common wear pattern on golfs due to suspension setup (described as 50p pattern).  Got our tyres replaced for this very reason, after rotating wheels to front and thinking I'd thrown a bearing cos of the stupid noise they made!
Build thread clicky
Offline richw911
« Reply #16 on: 17 December 2009, 17:18 »
http://www.golfgtiforum.co.uk/index.php?topic=92328.0
Offline barry-gti
« Reply #17 on: 17 December 2009, 20:14 »
By the way. you can get adjustable tie arms for the golf!  :smiley:
