Author Topic: throttle cable  (Read 1736 times)
Offline Dizzie
  • Make friends with your fast
throttle cable
« on: 03 October 2004, 21:54 »
what's the end that connects to the pedal like on a 1.8t throttle cable like?
The one I'm using now is too short and I've been told that's the longest I can get, but obviously the ones that come on the mk4's aren't as tight and almost go all the way round the engine. if I can connect the other end to my pedal then I'll shell out and buy one.
Mk4 Golf 150PD
Offline topher
  • Administrator
  • fully functioning
Re: throttle cable
« Reply #1 on: 03 October 2004, 22:00 »
bit dark at the mo, ill take a peak at it tomorrow if i remember  ;)
kniterider
Re: throttle cable
« Reply #2 on: 03 October 2004, 22:09 »
any throttle cable from a (AGU) engine should be ok as, the throttle butterfly is on the front side of the engine so you should have a pretty lenghtly cable, most of the other m4's that have a cable (no other 1.8t's other than the agu) are shorter as the buttery fly/throttle system is on the back side of the engine hence the short cable.
id try one of these, you should be able to pull up at a half decent vw dealers and ask em to get one out so you can size it up
Gaz 8)
