Author Topic: Couple of 8v technical help bits!!!  (Read 1605 times)
Offline Mr Blue
Re: Couple of 8v technical help bits!!!
« Reply #10 on: 10 November 2009, 18:15 »
Sorry what side is the fluid leaking? drivers side yes?
That could be the pump or just a lose pipe.
One pipe is ok to change, the other is a right pain and i'd leave it to a mechanic with ramps.
temp gauge.
Im sure you can bridge the two terminals on the temp sensor wire and see if the gauge works?
Check for broken wires near the plug also.
You could use your oil temp gauge on the MFA as a rough guide on how hot your engine is running.
Offline RhosneigrGaz
  • More Doors Crew!
« Reply #11 on: 10 November 2009, 18:22 »
You seem like a handy bloke to know!!!  :smiley: :smiley: :smiley:
Will get her on a ramp on Saturday and check pipes etc, bloody thing is soo low its impossible to see!!!
As for the MFA it has the stalk but deffo does not have the 'pooter!!!!
'02 3dr Tornado Red Gti 20v Turbo
