Golf mk2
damb blue temp sensor.....aaaahhh
Topic: damb blue temp sensor.....aaaahhh (Read 2018 times)
Alec
Re: damb blue temp sensor.....aaaahhh
Reply #10 on:
11 November 2009, 16:02 »
Temp sender tells the ecu the temperature of the water n whatever. Basically allows the ecu to control the fuel mixture
Bcarm
Reply #11 on:
12 November 2009, 16:48 »
Could this be the cause of my problems then, cold, runs great, warm/hot, pinks under exceleration, miss fires etc?
weazgti
Reply #12 on:
12 November 2009, 20:01 »
That sounds more like timing problems methinks.Could be wrong though,normally am.
Alec
Reply #13 on:
12 November 2009, 20:19 »
Has it always done it? Could also be the mixture screw? My knowledge is limited to be honest mate as I have gathered most of my info from the helpful chaps on this forum. I would of thought it was something to do with fueling, if it has only just started doing it after say a cambelt change then timing maybe as weaz says
Golf mk2
