Golf mk2
Arch cutting
Topic: Arch cutting (Read 5666 times)
richard s
Re: Arch cutting
Reply #10 on:
02 November 2009, 18:31 »
if your not mega low are you running 205 tyres
oldbealmk2
GTI forum regular
Re: Arch cutting
Reply #11 on:
02 November 2009, 19:13 »
Fully wound down on coilies
Mk2 work in progress
richard s
Re: Arch cutting
Reply #12 on:
02 November 2009, 19:41 »
in that case you should only drive on straight level roads
dan_apps
too low for british roads!
Re: Arch cutting
Reply #13 on:
02 November 2009, 20:20 »
you are gona be cutting alot of arch away if your that low! personally i would wind the coilies up abit and rol the arches! your gona hit all kinds of problems as low as you are and will get fed up with it! (pun in there sumwhere!
Ben Lessani
The poor mans MK2 Haynes author
Re: Arch cutting
Reply #14 on:
02 November 2009, 20:30 »
... and avoid speed bumps, kerbs and coins lying on the road.
richard s
Re: Arch cutting
Reply #15 on:
02 November 2009, 21:01 »
or leave it and surely the tyres and wings will come to some sort of arrangement between themselves
mwep201081
Here all the time
Re: Arch cutting
Reply #16 on:
02 November 2009, 21:14 »
The rear tyres will get julienne'd!
farmer
Re: Arch cutting
Reply #17 on:
03 November 2009, 08:42 »
http://www.vwcaddyforum.com/showthread.php?t=1864
found this link on here some where better rolled than cut
Its a gti world out there!
farmer
Re: Arch cutting
Reply #18 on:
03 November 2009, 08:47 »
Some one on here made that but using a wheel spacer insted of the plate and driling loads of holes in it... the jack u can find in the back of your car or down a scrapy
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: Arch cutting
Reply #19 on:
03 November 2009, 12:57 »
I used a hammer to flatten the lip on mine, worked with ET13 15" wheels. then i used a dremel to cut the plastic arch.
Golf mk2
Arch cutting
