Author Topic: upholstery cleaning  (Read 5213 times)
Offline Guy
Re: Massive interior overhaul :P
« Reply #10 on: 01 November 2009, 22:35 »
Awesome mate, think I have a vac in the garage that can suck up water. Not sure if that will work... will have a go tho.
Thanks for the tips.
james
james... where do you live?
Offline jimbooboo
  • YUM YUM
« Reply #11 on: 02 November 2009, 22:46 »
Barnsley in south Yorkshire.
Offline Guy
« Reply #12 on: 03 November 2009, 00:08 »
tis a bit far for me!  :laugh:
Offline mikemk4gti
Re: This may sound incredibly dumb.
« Reply #13 on: 07 November 2009, 22:25 »
you can hire a machine to clean them. My local Morrisons and Homebase do one with an upholstery tool for about £20 for a day so you can do the house and the car!
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline Jimp
« Reply #14 on: 08 November 2009, 11:21 »
jim
get yourself a decent degreaser... something along the lines of megs APC... dilute this down 4:1 in a spray bottle and use this to clean your plastics and headlining
for your upholstery.. your best bet is to shampoo material to get it looking its best... you will be surprised what a turn about you can achieve
find a friend with a 'george' with some APC and some autosmart 'brisk' or 'biobrisk' or rent a rug doctor http://rent.rugdoctor.com/ you will be amazed at how much dirt you can remove from seats and carpets...
vacuum your carpets thoroughly first... then shampoo the seats & carpets... use a short scrubbing brush like this http://www.vikan.com/sw3699.asp to scrub the material and work the cleaning agents into it and extract as much water as possible... you will need a day (min) for them to dry fully.
et voila http://www.golfgtiforum.co.uk/index.php?topic=89507.msg1186179#msg1186179
you can then use quick detailers and smellies etc for dressing... think along the lines of 'fabreeze'.. it only masks smells etc... but if you want it 'clean' then you will have to do the work above... it will then naturally smell fresher too.
Sorry if this is a bit of a stupid question, but when you are shampooing the seats and carpets and have scrubbed in the shampoo do you then dry off the surface stuff and leave it to dry or do you just leave it sit?
Not low enough mk5
Not on the road enough mk3
Offline Guy
« Reply #15 on: 08 November 2009, 11:44 »
jim
you have highlighted the answer... you extract as much water as possible.. they will be left slightly damp once you have extracted them and will need a day to dry fully
Offline paddy_coyle
Re: upholstery cleaning
« Reply #16 on: 08 November 2009, 16:05 »
I used a steam cleaner on my headling, seats and carpets yesterday, the results were fantastic
