Author Topic: mk2 golf rear axle.  (Read 3288 times)
Offline mac7
Re: mk2 golf rear axle.
« Reply #10 on: 02 November 2009, 23:03 »
the rear axles are designed to have a little give in them, mine bends slightly when I jack it up, are you sure it wasn't just bending because you had the jack in the middle.
I took mine off the other week, and even though it looks like 1 solid piece, it does actually have some bend and elasticity to it....
Little tip here - don't jack the car up from the middle of the beam. That's one sure way they get bent. The beam axle is designed to twist, not bend.
Golf R
« Reply #11 on: 02 November 2009, 23:28 »
I never jack them in the middle, where it mounts is a lot safer.
« Last Edit: 01 December 2009, 00:01 by Wayne »
Offline antogoof
  • bbm mk2 g60
« Reply #12 on: 04 November 2009, 17:01 »
i dint jack me car in the middle?!
done now anyway new axle in, new stub axle both sides, bearings and brakes.
its in for the m.o.t sat.....wish me luck!!!!!
mk2 bright blue met bits wanted in north west.
