Author Topic: losing temp mk 4 1.8t gti  (Read 2109 times)
Offline madmk4
« on: 29 October 2009, 20:54 »
driving home today when i noticed the temp gauge had droped from 90 to 0 i stopped and switched it off left it a few minute started again and back to 90 for a few miles dropped any ideas what this could be cheers
gtigolfthree
Re: losing temp mk 4 1.8t gti
« Reply #1 on: 29 October 2009, 21:16 »
Its either a fault with your gauges sender unit or a problem with your thermostat. Is your heater still hot when the gauge drops?
Offline madmk4
« Reply #2 on: 29 October 2009, 21:18 »
yea it still blowing  hot and the fan still cuts in and out
gtigolfthree
« Reply #3 on: 29 October 2009, 21:55 »
It will be a gauge issue then, either a dodgy electrical connection or more likely a faulty sender unit.
Offline madmk4
« Reply #4 on: 30 October 2009, 08:57 »
got one order getting it fitted at lunch will update later  :smiley:
Offline mac456
« Reply #5 on: 30 October 2009, 09:41 »
temp sender - 10mins to fit
Offline madmk4
« Reply #6 on: 30 October 2009, 18:50 »
hope u can help had the car booked in at lunch to get the temp gauge sender unit changed and they had order the 2 pin unit instead of the 4 pin apparantly , going back tom mornin , anyway on the way home tonight the engine managment light came on would this temo unit cause this light to come on , cheers martin
Offline madmk4
« Reply #7 on: 30 October 2009, 21:14 »
any1 ? :)
Offline T_J_G
« Reply #8 on: 30 October 2009, 21:37 »
Post in the mk4 section. I'd replace your temp sender and thermostat with genuine VW items.
Offline madmk4
« Reply #9 on: 31 October 2009, 21:51 »
all sorted replaced the temp sender from vag and engine managment light has gone out well chuffed cheers  :smiley:
