Author Topic: lights on?  (Read 1295 times)
Offline weazgti
lights on?
« on: 26 October 2009, 21:45 »
Changed my blue senser on my 8v digi today to try to sort out the under load holding back issue and all seemed well.Had full throttle instead of it holding back for a bit and i was quite chuffed that it was going well.
Then in the evening as it got dark,put the lights on problem still there as in very sluggish then after a while it pulls normally.Also noticed the idle speed is higher.
Definatly to do with the lights because as soon as i turn them off and blip the throttle the revs drop down to normal.
Ihave gone round the earth points with a multimeter and cleaned them just for the sake of it but no difference and i did feel like i was wasting my time because somebody has already replaced some of the earth cables.
I really do not have a clue what to look at next so does anybody out there have some idea why puting my lights on would make my car run rough?
Also the water temperature stays on the 1st white line on the gauge while driving which seems bit too cool to me but i do have heating.Am i right in thinking that this would have an effect on my blue senser seeing as it sits in water flange?
« Last Edit: 26 October 2009, 23:14 by weazgti »
Offline tony_ack
Re: lights on?
« Reply #1 on: 27 October 2009, 00:39 »
Sounds like something is earthing on the lights circuit, or the lights circuit is grounding on something it shouldn't. I know you've checked the earths, but I imagine there is a bad/unwanted contact somewhere.
With the temp gauge, you didn't mention whether it was working before you changed the blue sensor?
If it was working before, there's a black sensor next to the blue one which sends the temperature signal to the gauge on the clocks - make sure you didn't disconnect it when doing the blue sensor, or disturb a wire. With the wiring in these cars being 20 years old +/- it's possible that some wires may have been hanging by a thread, until they were nudged and broken.
If the temperature has always been cool, check the thermostat is coming on when it should (i.e. the bottom radiator pipe should be stone cold until the engine is warm). If the bottom pipe warms straight away, you need a new thermostat as it's stuck open.
If the thermostat is okay, the next two things to check would be for airlocks, and whether the gauge in the dash is working
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
Offline weazgti
Re: lights on?
« Reply #2 on: 27 October 2009, 08:53 »
Temp gauge works ok it does warm up eventually if i sit in traffic just bit too cool when im driving,even on a really hot day.
Didnt think much of it because the heating works ok but will check it anyway today and see what the thermostat is doing.
Only other thing i found was the knock senser had a crack in it.Would this give me problems related to my lights?
I know i need to change it really but was just wondering whether it could have something to do with it?
Wiring is not my strong point on cars
« Last Edit: 27 October 2009, 08:55 by weazgti »
Re: lights on?
« Reply #3 on: 27 October 2009, 10:56 »
what voltage do you get at battery with engine on with lights off, then on?
Offline weazgti
Re: lights on?
« Reply #4 on: 27 October 2009, 11:07 »
wait ill go check
Offline weazgti
Re: lights on?
« Reply #5 on: 27 October 2009, 11:14 »
13.78 off 13.63 lights on
Re: lights on?
« Reply #6 on: 27 October 2009, 14:24 »
hmm nowt wrong wi that then. are the lights mega 6 billion W illegal jobbers or just bog std H4s
Offline weazgti
Re: lights on?
« Reply #7 on: 27 October 2009, 22:01 »
lol no just standard stuff.once warmed up today went fine but this evening with the lights on it just judders slightly when cruising and bogs down when i put my foot down.
sounds daft really dont it?
All this is since i done my head gasket few months ago.
