Author Topic: RCD 510 + Fiscon  (Read 19706 times)
Offline p3asa
Re: RCD 510 + Fiscon
« Reply #50 on: 11 April 2010, 12:09 »
Thanks, hadn't noticed there was a smaller clip!
Also, how did you feed your wire from the stereo? Mine comes out under the steering column, then out under the fuse box panel.
Basically the same. then just peel the rubber door seal back a wee bit and run it up the A frame.
The only bit the wire can be seen at is the bit it comes out of underneath the fuse box till it reaches the door hinge side. However the trim splits at this part and you can run it in this channel and its not seen that much!!
Offline Sebby
  • Golf VI GT TSI
« Reply #51 on: 11 April 2010, 23:45 »
Thanks, got it neatened up today. I have actually managed to have no wire showing...
Golf VI GT TSI 1.4 160PS, 18" Vancouver alloys, air conditioning '2Zone', luxury pack, winter pack, RCD 510 with Dynaudio, parking sensors
