Author Topic: Tatty Corrado - holistic healing continues  (Read 159078 times)
Offline Horney
Re: Dirty black Corrado - holistic healing project
« Reply #170 on: 24 March 2012, 08:00 »
Is this so you can ABF the corrado and use the whole loom?
Nick
Offline clipperjay
« Reply #171 on: 24 March 2012, 08:13 »
Cunning tools.
I will probably only use a two bits of these:
The VAG terminal tool
The flat-blade screwdriver
The damned thing I need to eject the wires from:
Push thin tweezery things in either side of hole.  This depth is easy:
But you need to penetrate as deeply as possible - ALL the way:
Getting that deep takes some pushing.
Once it's all the way in you just pull (quite hard) and the terminal comes out the back of the connector block.
Speedo drive, ready for application:
I want one of those it would make my life so much easier!
Didnt know you had this DH!
Offline JC
  • Back in the North.
« Reply #172 on: 24 March 2012, 08:14 »
And it all becomes clear  :grin:
Is that Easter weekend sorted ?
Offline Diamond Hell
  • Opinions я Us
« Reply #173 on: 24 March 2012, 10:24 »
If you want one, buy one: http://cragmay.co.uk/product_info.php?products_id=356
 :grin:
Kinda.  This is so I can either re-loom the motor that's in there at the moment, or swap out motor and loom together.
The issue with the last set up was that it was an early loom and ECU and late motor.  The two didn't seem to get on and the loom didn't seem to get on with the Corrado fusebox at all.
The most important thing is to get everything on the Corrado working spot on, as it won't pass an MOT without working ABS now.
The other thing that was behaving strangely when it was taken off the road, was an odd resonance from the engine at certain revs, after the front sub-frame was replaced with a Golf3 one, when the lower control arm securing bolt sheared off.  I've now sourced a replacement Corrado sub-frame, so that should resolve this odd issue, along with everything else.
Oh and of course, the Cordoba has 280mm front stoppers, which will go straight on the Corrado.
  • Opinions я Us
« Reply #174 on: 25 March 2012, 09:03 »
So, the first step in an engine conversion is to do something pretty much unrelated, so yesterday I took the Cordoba out to the barn and took the engine out of the Vitara that's been littering up the barn WAY too long.
What that meant is that there was a spare space out of the eight vehicles that can easily fit in the barn, so the Cordoba is now inside.
When I was driving it out to the farm, with the sunroof open and the air-con on it did occur to me that it has air-con.  This is something the (black) Corrado doesn't have.  Thus, not only is this now likely to be an engine conversion, it'll also be an air-con installation, as I hate hot cars, but The Wife loves black cars.  This way we should get a cool, black Corrado out of this.
Now, as part of this holistic project I need to finish the SJ work.
Offline stow1985
  • 'when im cleaning winders'
« Reply #175 on: 25 March 2012, 22:38 »
Why not just keep the Seat  :grin:
  • Opinions я Us
« Reply #176 on: 25 March 2012, 22:49 »
Because the Corrado doesn't suck.
Offline stow1985
« Reply #177 on: 25 March 2012, 22:50 »
 :grin: :grin: :grin:
Offline danny_p
« Reply #178 on: 25 March 2012, 23:06 »
ummm  retrofitting air con,  that the project  swaping engin eloom is just a minor detail
all the VW's have gone bar 1.
  • Opinions я Us
« Reply #179 on: 26 March 2012, 14:48 »
Well it's there and I do hate sitting in cars sweating in the summer.
Especially black ones.
