Author Topic: RCD510 + DYNAUDIO: Missing some bass...  (Read 2355 times)
Offline nuketronic
« on: 19 October 2009, 15:07 »
Got the RCD510 plus DYNAUDIO, but im missing some bass "umpf". Anyone upgraded their system with a 10" or 12" sub? Im looking to get one of those, probably the shallow ones, to occupy less space in the boot? can anyone suggest a decent setup?! gracias!
Offline maksta
RCD510 fitted with a subwoofer - anyone done this???
« Reply #1 on: 19 October 2009, 18:03 »
Hi
i have wk 48 build golf gti with RCD510 (without dynaudio) and was planning on using my 12inch vibe sub with this unit. has anyone tried this????
i have been unable to find out whether the RCD510 has any pre-amp outs? im guessing not! having spoken to ICS who fit subs, they said that they can use the speaker channels to get a signal if it does not have any pre amp outs. has anyone tried anything similar to this??
i also spoke to VW who told me that the warranty would become void, if say the RCD510 unit had a problem which was a result of doing this(which is fair enough), however i was told that if it was something else electrical which is not related to sound system, the warranty should be fine.
any thoughts or advice???
Offline Emeye
Re: RCD510 + DYNAUDIO: Missing some bass...
« Reply #2 on: 20 October 2009, 22:41 »
There may be an Aux out from the RNS510, but IIRC it's difficult to tap into as I did investigate getting an RNS510 and was interested on how to connect it up.
You can either get a powered sub with speaker level inputs - or buy a line level converter and run either from the rear speakers.
Offline maksta
« Reply #3 on: 20 October 2009, 22:58 »
cheers mate, i spoke to an ICE fitter today and they told me a similar thing to your post above. something about a high / low converter to get a signal from the rear speakers i think he said!
still got a while to decide what i want to do.
 :cool:
