Author Topic: 1990 Golf GTI 16v  (Read 91952 times)
Offline Mew
Re: Mew: Got another one!
« Reply #80 on: 25 March 2010, 18:19 »
Progress report:
It's gone backwards.
I have just totalled up a list, and if i were to go and buy all the parts that i need it would come to just over £500 :sick:
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
« Reply #81 on: 25 March 2010, 18:41 »
sounds good to me. vr6 it and forget all your woes.
Offline Mew
« Reply #82 on: 25 March 2010, 19:00 »
Only £100 or so is engine related, the main chunk is discs, pads and bearings
Offline Mew
« Reply #83 on: 16 June 2010, 10:45 »
New rear discs, pads and bearings ordered.
I had a look at the rear bearings yesterday as they have been groaning slightly, but having jacked up the rear there was no play present in either side at all. After reading around I found that the nut should be finger tight only and there can be a tiny amount of play present.
Well mine were done up stupidly tight, so i'm guessing there has been play in the past and that they've been tightened up, or they were over tightened in the first place which has caused the bearing to fail. I backed them off a bit until they were finger tight which introduced a slight amount of play, but after a quick roadtest it appears that they're definitely gone, so they're being replaced asap.
Offline JC
  • Back in the North.
« Reply #84 on: 16 June 2010, 11:29 »
never touched the rears on this - so you cant blame me  :tongue:
cant believe the engine is still going on this  :shocked: should have kept it  :lipsrsealed:
Offline Mew
« Reply #85 on: 16 June 2010, 11:34 »
I didn't blame you, but now i'm wondering if i should? :tongue:
Engine is still going, not well though! Very tappety, suspected leaking injector, struggles with hot starts, throttle body needs replacing/refurbing and i need a new (obsolete) oil breather pipe. I just need a job/lottery win to pay for it all :cry:
Offline JC
« Reply #86 on: 16 June 2010, 11:37 »
throttle body - you checked you spares box  :huh:
injector - should have taken the other engine  :tongue:
oil pipe - again have you checked you spares  :huh:
Offline Mew
« Reply #87 on: 16 June 2010, 11:46 »
Yep, one in there, just haven't got round to it
Quote
That didn't have them, did it?
Quote
Yep, nothing :sad:
Offline Chris-White
« Reply #88 on: 16 June 2010, 12:39 »
Quote
Ive still got the ones off that duff engine we had a few years ago kicking around.
Offline Diamond Hell
  • Opinions я Us
« Reply #89 on: 16 June 2010, 13:00 »
Are you two schizophrenic, the same person using different logins or a married couple?
I'm never sure.
