Author Topic: 1990 Golf GTI 16v  (Read 91961 times)
Offline Horney
Re: Mew: Got another one!
« Reply #110 on: 03 July 2010, 14:34 »
Sounds like a true story and the tone is not that of some kinda of messer. Shame.
Nick
Offline Mew
« Reply #111 on: 03 July 2010, 15:00 »
He said he'll pass my details onto the guy that is coming to collect them. Very much doubt anything will come of it though :sad:
Offline Mew
« Reply #112 on: 05 July 2010, 17:51 »
Today i found this:
It's the wiring and connector for the idle switch on the throttle body. Pretty knackered!
Offline Mew
« Reply #113 on: 06 July 2010, 15:03 »
Throttle switch connector now repaired. I haven't done it with the original connector, but I've crimped on some connectors that will do the job until i get an original connector to put back on.
The idle has stayed the same, but sometimes there is a bit of a dip in revs when coming off the throttle, so a proper timing and idle/CO set-up is in order asap. The switch definitely works though, hold throttle open at around 2k rpm and press the throttle switch and the revs drop back down.  :smiley:
Offline Mew
« Reply #114 on: 12 July 2010, 22:47 »
Well, it all went a bit wrong the other day, the result of which was more oil on the a34 than in the engine.
Fault finding consisted of stripping down the top end and as a result i've narrowed it down to either a crank seal or (the one that i'm taking a gamble on being the cause) the cam seal. However, I have found a mystery inlet cam that is stamped "933" where the VW stamp of "027" normally is. I've measured it and it seems to have a lift of 8.9mm compared to the KR inlet's 9.6mm, so I'll be rebuilding it all tomorrow with a set of KR cams :smiley:
VeeDubGTI16v
« Reply #115 on: 13 July 2010, 10:27 »
possibly a 9a inlet?
Offline Mew
« Reply #116 on: 13 July 2010, 10:38 »
I expect so. Cgti guide has the 9a down as having 8.8mm lift. I'm measuring 8.94 pretty consistently, but either way, its not what it should be!
Offline JC
  • Back in the North.
« Reply #117 on: 13 July 2010, 10:54 »
so that top end rebuild and head gasket reciept has a lot to live up to then - bet this cures ya rattle too  :lipsrsealed:
Offline Mew
« Reply #118 on: 13 July 2010, 11:20 »
It would be good if it did, although I can't see how it will :sad:
Offline JC
« Reply #119 on: 13 July 2010, 11:22 »
stranger things have happened with that car  :grin:
you still got the lifter we removed from the other lump ? time to stick them in perhaps  :undecided:
