Author Topic: 2.0 TDI 170 PROBLEM  (Read 3672 times)
Offline Schuey
Re: 2.0 TDI 170 PROBLEM
« Reply #10 on: 25 October 2009, 23:38 »
Blocked cat or backbox ? if it dont chuck out black smoke then boost pipes are ok ! if no codes then maybe exhaust prob , can you unbolt just the rear box and try without it or is it a one piece factory system every car seems to have lately ?
trouble is if its blocked exhaust prob it should dob it at all revs and be underpowered
It's definitely lost power!, Emissions are fine so expect it wouldn't be the cat?  Car was serviced by a main dealer last week & they said nothing was wrong.
I may take off the back box & give it a try then.  :undecided:
Thanks  :smiley:
Offline Rhyso
« Reply #11 on: 26 October 2009, 11:47 »
need to get someone with VAGCOM to go for a drive and monitor the values of the MAF as it sounds more and more than the likely culprit
