Author Topic: cd changer and aftermarket headunit  (Read 4586 times)
Offline navmk4gti
« on: 15 October 2009, 19:16 »
right im planning get a alpine headunit.. but i have a indash cd changer.. do i need to get a certain type headunit becuase of this or will any do??
i know i will need an adapter  :smiley:
Offline dragonfly
Re: cd changer and aftermarket headunit
« Reply #1 on: 15 October 2009, 20:33 »
Are you planning to simply replace the standard in-dash headunit for an Alpine? Are there any steering wheel controls? Is any track information displayed on the dash for the standard unit?
Offline navmk4gti
« Reply #2 on: 15 October 2009, 20:36 »
Are you planning to simply replace the standard in-dash cd player for an Alpine? Are there any steering wheel controls? Is any track information displayed on the dash for the standard unit?
im replacing standard cassete player.. i have a in dash cd changer hooked to it.
heres pic
Offline dragonfly
« Reply #3 on: 15 October 2009, 20:45 »
Ok you can either consider a double din headunit, get a single din headunit and leave the cd changer, get a single din headunit and replace the cd changer with a pocket/storage tray.
Either way pull out the standard cassette player and have a look at the connections - if they are ISO then you won't need a connector (unless you have steering wheel controls) most aftermarket headunit will fit straght in. Check the aerial connector in case you need an adaptor for that.
Offline navmk4gti
« Reply #4 on: 15 October 2009, 23:39 »
yh the back is an iso block.. my cd changer does connect staright onto iso block but my standard unit has 3 slots wheras aftermarket ones normally have 2  :undecided:
so i presume the cd changer wont work with it then.. if i get a double din will cd changer work fine from it? as i have personally never seen double din connecitions so no idea on them
cant you get connectors from my standard cd changer to the single din alpine headunits  :smiley:
Offline troublestarter
« Reply #5 on: 16 October 2009, 09:18 »
a vw changer will only work with a vw h/u
surely if your new h/u is mp3 then you won't need a changer anyway
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline dragonfly
« Reply #6 on: 16 October 2009, 09:23 »
As above do you really want to keep the standard cd changer?
Offline navmk4gti
« Reply #7 on: 16 October 2009, 11:48 »
i would of liked to yes.. but if its not possible then .. ill just settle with mp3.. i may just get a double din then it will look better  :wink:
Offline dragonfly
« Reply #8 on: 16 October 2009, 11:59 »
Go for either the double din, you can get ones that do virtually everthing - bluetooth, MP3, iPod etc. Or settle for a single din and leave the changer/replace with a pocket.
As you are in Birmingham try here: http://www.thebassbin.co.uk/
Offline navmk4gti
« Reply #9 on: 16 October 2009, 13:06 »
yep mate im frum birmingham.. seen dome good pioneer double dins for around 150 on ebay  :smiley:
