Author Topic: Cant get Iphone to Work ....?  (Read 14007 times)
Offline p3asa
Re: Cant get Iphone to Work ....?
« Reply #20 on: 17 October 2009, 20:55 »
hi all i was wondering whether the iPod adapter thing keeps the iPod in charge as well as the obvious task of playing the music, and presumably allow control of changing tracks and suchlike on the steering wheel buttons? I'm considering getting either an iPod Classic or iPod Nano, just as a convenient place to store the my own preferred tunes, and then just leaving the iPod in the car all the time. i presume it does but i thought i might ask as i have never owned or used anything iPod related before
You may want to try an ipod first before buying one as there is an annoying (well it is to me) pause as it changes track
http://www.golfgtiforum.co.uk/index.php?topic=131370.30
I was on a 2 hour journey today and the problem was really evident and annoying. So much so I switched to the radio.
I think I'll invest in a SD card and see if that cures the problem.
Offline Mighty_G
  • Tornado Red MK6 3 Door, 18 inch rims, AAC, RCD510
« Reply #21 on: 17 October 2009, 21:36 »
doesn't pause on mine ?
Ipod is brilliant in the car, i use itunes to subscribe to lots of good podcasts, now I plug it into the home pc once a week and upload them so gives me a load to listen to when I don't want to listen to music. Also on itunes you can make playlists so you can make a set of songs for different driving moods (chilling out, rockin, general mix e.t.c.)
Offline DDRFan
« Reply #22 on: 17 October 2009, 22:06 »
hi thanks for your input. to be honest i think the USB option seems better for me, although when (or if  :rolleyes: ) I get the car I'm gonna see if i can borrow somebody's iPod and test it during collection (make sure i get the right cables and stuff)
as for the pause during tracks, i would hazard a guess that even the USB option will not cure it. the reason i think this is i simply think the audio system is not sophisticated enough. imagine you are the audio system (effectively it's just like a computer) and you are playing an MP3 file, say "sweet_child_o_mine.mp3". You're spending all your CPU cycles reading the MP3 file from the USB stick, uncompressing the data into an output buffer, then the sound comes out from the data in the output buffer, then when that buffer is played, it is filled again from more data from the CPU.
suddenly the CPU reaches the end of the track. i don't think it is likely this audio system is clever enough to know when it reaches the end, it just stops. the CPU would have been busy trying to play "sweet_child...mp3". so it has to stop. then it will probably need to clear the buffer that has the ending of the track, which will take a bit of time. then it has to look through the USB stick for what the next track is, and electronically this will take time depending on the speed at which the USB can feed the CPU data. once found, data is then read by the CPU and it starts to uncompress filling in the output buffer and music comes out again. but all these minute steps are taking place within fractions of a second, however as you have noticed puts a tiny skip in the music.
to solve this problem the CPU needs to be clever enough to know when the end is approaching, and then start to read the next track, doing this whilst playing the end of the existing track. it's probably too much to handle for the CPU, and from a programming point of view it's just easier and cheaper to implement just basic playback, and just put up having the tiny gap in the music.
alternately you just have one huge-arse MP3 and it just plays from beginning to end with no pauses
but then again i have no personal experience of this system and i could be talking completely out of my arse, i just know from playing MP3s on my PC you sometimes get the tiny skips and i would expect the same on this GTI sound system too. Certain software like WinAMP will 'fade' the previous track and new track so it seems more seamless.
*edit* as a side note before i completely go off topic, one of the main reasons I wanted a GTI is because of the driving thing, not really for the music system - i could still live with CDs if i had to, in fact to be bluntly honest most of the time I have the radio tuned to BBC Radio 5 Live (AM radio qualtiy ftw :rolleyes: ) but sometimes it is nice just to be thinking of song whilst driving and just put it on.
« Last Edit: 17 October 2009, 22:10 by DDRFan »
Offline Rolfe
« Reply #23 on: 17 October 2009, 22:22 »
Yes, the iPod adaptor will charge the iPod or Iphone when connected and you can use the buttons on the steering wheel to select your songs and all from the display...
Yes it helps thank you.  :smiley: Now I sorta have to decide whether I really do want to get an iPod, just for the car... i suppose it's better than juggling all the CDs... the car before the one I got had a radio cassette! i still remember that and think how so much better having CDs are because you could easily just skip tracks.
I had an iPod that I put through the washing machine last Christmas, which totalled its screen.  It was working OK apart from that but in the end I got a new one because it's almost impossible to find what you want without a screen.
The original one now belongs to the car, giving me all my playlists at the touch of a button.  And of course the car's screen displays all the track titles so the iPod's own screen being bust doesn't matter.  I haven't had any of these problems with the start of tracks.
Rolfe.
Offline p3asa
« Reply #24 on: 17 October 2009, 23:05 »
I don't mean I want it to play gapless.
And I have probably titled it wrong by saying it pauses. Its not pausing as such. It starts to play the next track and then the sound cuts out then re starts. Its not noticeable at all on tracks that start quietly but is very noticeable on tracks that start loud.
Your theory sounds plausible but it is also not present on all ipods. That thread I linked to has a very rough list of what ipods appear to be affected but even that doesn't seem to have any pattern.
My itouch sometimes is fine but like I said earlier it was terrible today but now I think about it, it may be because I was on the motorway and the volume was up loud so it may have exacerbated the problem.
Offline DDRFan
« Reply #25 on: 17 October 2009, 23:12 »
.... It starts to play the next track and then the sound cuts out then re starts. Its not noticeable at all on tracks that start quietly but is very noticeable on tracks that start loud.
OK i think i know what you mean.... sort of like if you're out in a club somewhere, dancing like a bell-end and getting into the beat, and then the DJ accidentally loses the needle and the track stops and you're still dancing, and then the DJ realises there is no music so switches to his spare quickly
that would annoy me too i think, so much so i would probably just turn off the music completely
Offline p3asa
« Reply #26 on: 18 October 2009, 23:28 »
 :grin: eh something like that  :laugh:
Offline gc76
« Reply #27 on: 19 October 2009, 12:12 »
Ive heard that a couple of times with my iPhone aswell.  Will be intresting to know how to cure it, if at all possible
Tornado Red 5 door GTI, DSG, Monza Shadows, Lux Pack, RCD510, Park Assist & FT indicator
"Sounds just like a Golf"
Offline p3asa
« Reply #28 on: 19 October 2009, 21:39 »
I was thinking about this today, and on the original post most folk (if not all) reckoned it to be a fault with the ipod rather than the stereo. However my last car as well as my wife's current car had ipod adaptors to allow them to play ipods and none of the symptoms ever happened.
I think it might be a fault with the RCD510 rather than the ipod.
Offline DDRFan
« Reply #29 on: 19 October 2009, 22:22 »
... I think it might be a fault with the RCD510 rather than the ipod.
i presume you could test your iPod/iPhone on the many accessories now available designed to work with these devices such as these alarm clock docking stations like this one (link below), presumably if it doesn't have these little pauses on that, but you take the same iPod/iPhone to the car and it still pauses, then you are right, indeed it is something odd with that that system.
http://www.play.com/Electronics/Electronics/4-/7126953/Play-com-iPod-Alarm-Clock-Speaker-Dock/Product.html
